wth. Buy this light or not? The price seems good…
How much lumens? Runtime? How much flood? How far will it throw!?
I know you are looking for our more spec-minded members to weigh in (I am, too), but I’ll just say this in the meantime; while I don’t have the equipment to do these fancy numbers tests, when Rusty says something is bright, it is bright. This is why I am real darn careful to make specific lumen claims.
But if you like “pocket power” and are into the C8 format, then why pass this by when it is the perfect combination of modern technology, flood/throw, build quality, beauty, regulation, and just plain all-round usefulness? It’s the brightest C8 I’ve ever handled (and I’ve owned 12 of them) and throws pretty far—better than many smooth-reflectored lights. To me, that would say something.
Then again, you may have ten other good C8s at home and may not need another. But one good one goes further than about twenty regular ones, I say. So, no, whether or not you need one is ultimately up to you. This is for sure going to be on my “lights of 2014” list, hands down. Again, what does that tell you?
Lovely. Would it be possible to get an outdoor night beamshot just before I snap this up?
Can it use protected cells? And what is your estimate on throw?
I’ll bring it out tomorrow night and take a couple of shots. And yes, it can use protected cells. I’ll give the estimate tomorrow.
I think he don’t have T4 5B1 anymore based on his LED list but instead T5 5B1 which is same tint but a little brighter and without the 80+ CRI (around 75CRI), should not be a huge difference, alternative for +80CRI are T4 6A3 but its warmer. Usually he change the price after you have order so you have to wait before paying the order but if you have already paid I think you can order an item and he can change the price to $1.75 for the price difference.
But don’t worry about the non 80CRI version because tint are the most important, I have 90+CRI LED and to my eyes it look worst because the tint is too yellow to my taste.
If you don’t pay the difference you will have the stock version : XM-L U2-1B with 6*7135.
Its a matter of personal preference I think, for me its perfect. :bigsmile:
Here is my Ak47 and Tangsfire with their older brothers my L4 and UF Xml-T6 :bigsmile:
Comparison of their beam in the same sequence and look like Tangsfire is the brightest followed by L4, AK47 and UF Xml-T6
Nice pics.
Only see 3 beams.
The first on the left appears to be the brightest. Isn’t that AK47?
I agree but you wrote that:
90 CRI LEDs are usually warm, just like 7A4 which is not only yellow but also orange.
There are 4 beams. UF is barely noticeable.
Did you mod your L4? Mine is probably 3/4 the output of my tangsfire, both stock.
Nice pics.
Only see 3 beams.
UF beam is the most right not very clear in the pic and the most left is Convoy L4 not AK47. From my naked eye view when you joint their hotspots together Tangsfire is just a little bit brighter than L4…
Not both mine are stock too but when you switch on the L4, it is brighter than Tangsfire just for a second but planning to dedome and copper braid the spring of my UF Xml-T6…
You can barely or make out or imagine a faint blob like a water color smudge
I just got mine yesterday in the mail. Absolutely love it! But does anyone know what the run times are for this flashlight? I’ve looked all over and I can’t seem to find any reviewers testing run times. I guess it would depend on the type of 18650 you’re using, but any number would be better than nothing.
Depends on the type of 18650+ driver ... @2,8A ~1h, @1,4A ~2h, @0,2A ~15 hours.
I got the Convoy C8 mentioned in this post at the beginning: Convoy C8 Cree XM-L U2-1B 2-Group 3/5-Mode LED Flashlight AMC7135*8 - from FastTech. I’m using a locally bought (Taiwan) 18650 2800 mAH protected. Not sure if it’s an ICR, NCR…
Received mine and I’m impressed with the quality. Absolutely destroys my UF C8’s :bigsmile:
I measured between 2.7-2.8 Amps at the tail of all my Convoy C8’s. Considering stacking some more 7135 chips but would this result in perceivably increased output or simply waste energy in the form of heat? It seems 2.8A is quite a ‘sensible’ current level with no significant overheating issues. Thoughts?
For those wanting more pics (I apologize ahead of time. These really are bad pics)…
Control (about 200-some-odd feet to that conference center wall)
High
Control (about 250 feet to that wall)
High
High mode (about 65 feet to the parking garage)
Haha guys Thanks for the beamshots. I think my money is going to a multi-tool I’ll get the c8 later I guess. Can’t have everything NOW in life unless you are filthy rich!
If you prefer to see them all in a side by side comparison, I’ve collaged the photos:
From top left, bottom left, top right, bottom right - control, low, medium, high
