Here is my Ak47 and Tangsfire with their older brothers my L4 and UF Xml-T6 :bigsmile:
Comparison of their beam in the same sequence and look like Tangsfire is the brightest followed by L4, AK47 and UF Xml-T6
Nice pics.
Only see 3 beams.
The first on the left appears to be the brightest. Isn’t that AK47?
Its a matter of personal preference I think, for me its perfect. :bigsmile:
I agree but you wrote that:
But don’t worry about the non 80CRI version because tint are the most important, I have 90+CRI LED and to my eyes it look worst because the tint is too yellow to my taste.
90 CRI LEDs are usually warm, just like 7A4 which is not only yellow but also orange.
There are 4 beams. UF is barely noticeable.
Did you mod your L4? Mine is probably 3/4 the output of my tangsfire, both stock.
Nice pics.
Only see 3 beams.
UF beam is the most right not very clear in the pic and the most left is Convoy L4 not AK47. From my naked eye view when you joint their hotspots together Tangsfire is just a little bit brighter than L4…
Not both mine are stock too but when you switch on the L4, it is brighter than Tangsfire just for a second but planning to dedome and copper braid the spring of my UF Xml-T6…
You can barely or make out or imagine a faint blob like a water color smudge
I just got mine yesterday in the mail. Absolutely love it! But does anyone know what the run times are for this flashlight? I’ve looked all over and I can’t seem to find any reviewers testing run times. I guess it would depend on the type of 18650 you’re using, but any number would be better than nothing.
Depends on the type of 18650+ driver ... @2,8A ~1h, @1,4A ~2h, @0,2A ~15 hours.
I got the Convoy C8 mentioned in this post at the beginning: Convoy C8 Cree XM-L U2-1B 2-Group 3/5-Mode LED Flashlight AMC7135*8 - from FastTech. I’m using a locally bought (Taiwan) 18650 2800 mAH protected. Not sure if it’s an ICR, NCR…
Received mine and I’m impressed with the quality. Absolutely destroys my UF C8’s :bigsmile:
I measured between 2.7-2.8 Amps at the tail of all my Convoy C8’s. Considering stacking some more 7135 chips but would this result in perceivably increased output or simply waste energy in the form of heat? It seems 2.8A is quite a ‘sensible’ current level with no significant overheating issues. Thoughts?
For those wanting more pics (I apologize ahead of time. These really are bad pics)…
Control (about 200-some-odd feet to that conference center wall)
High
Control (about 250 feet to that wall)
High
High mode (about 65 feet to the parking garage)
Haha guys Thanks for the beamshots. I think my money is going to a multi-tool I’ll get the c8 later I guess. Can’t have everything NOW in life unless you are filthy rich!
If you prefer to see them all in a side by side comparison, I’ve collaged the photos:
From top left, bottom left, top right, bottom right - control, low, medium, high
ISO200 but i think your exposure is long 1-3s?
Yeah, according to the picture data, they were all at 1 second. Sorry, my point and shoot has limited features in program mode. I couldn’t manually set the exposure time. Still, I think it’s a pretty accurate representation of what I’m actually seeing outside my window.
The idea of higher exposure is to convey accurately that “wow” affect. Overexposure is closer to my eye’s take on some of these pocket-rockets at turn-on. Too often, I keep seeing these lessened beamshots that might ought never to have been posted since they don’t accurately convey how bright a light is. We all know pictures can be deceiving anyway, but we still want to see what a light can do.
So… are you saying that the pictures I posted don’t do the flashlight justice? I would think that a picture that is an accurate representation of what is actually seen is better than “padding the stats” and showing a picture that makes things look brighter and more effective than what is realistically taking place. If I’m misunderstanding, I apologize.
Hi Rusty and OrionLight, thanks for sharing your impressions and the beamshots. Do you own XinTD C8 V4? I have one of those and even had it modded by TomE. Then I felt no need for other C8s and gifted them away.
Do you think I will be happy with this one even though it might not be as bright and throwy?
Thanks!
