Hmm, this could maybe be a YiboYuan charger. The box is identical but without the YiboYuan name on it (comparing to pics on DX).
-Garry
-Garry
Garry,
This is the same one I have and it works well, just charges slow. Terminates at 4.35 like a champ.
I bring up the cells to 4.20 on another charger, then top off with this one.
Runs cool, no problems.
HTH
Keith
I have yiboyuan universal version, and it is very good.
I can charge any cell phone battery, it is adjustable.
I got it from DX, which is the same one on this link
It do not look great, but it might be usable.
Has CY1 a couple of approval marks on it? If not, I would be very careful with using it.
Interesting idea. I wonder why it's all old-school, through-hole components. I took a gamble and ordered one from Tmart. Thanks for the report Garry.
I've found some YiboYuan AC-10 chargers on EBay which are 600mA rated. Think I'll order two of those.
-Garry
Probably a stupid question, but which battery contact is positive and which is negative?
Check them with a meter. I haven't used mine.
-Garry
Got it, thanks! Positive is on the left and negative is on the right. (On mine at least.) I can’t believe I didn’t think of that! :8)
Well today I received my two new YiboYuan chargers I ordered on Ebay (see post#26 above). Came from a US Warehouse, not extremely fast, but not terribly slow either (faster than Tmart!). I did in fact receive YiboYuan chargers, HOWEVER I received two model AC-11's and not AC-10 (it was only the photos in the Ebay listing that showed AC-10, it wasn't stated anywhere in the listing). I don't think this is a big deal though since I can't spot any difference between an AC-10 and an AC-11. Both are 4.35v @ 600mA charge rate with a USB output as well.
In any case, here are some pics:
The internals don't look as sophisticated as the first charger. My first question is, where is the AC -> DC circuitry (i.e. the 4 way bridge rectifier circuit)? So how does this one look? Does it look safe?
-Garry
No response?
-Garry
Cheap equipment sometimes only uses one diode not a bridge rectifier.
It does not look safe for 230VAC.
Thanks HKJ. Well I won't ever use it on 230V AC. So you think it's safe for 120V AC use? And what is controlling the charge termination? I don't see an IC like I would expect.
-Garry
I cannot say it is safe, but if the blue part beside D3 has some safety approvals it might be (I expect it is placed between mains and low volt side).
It looks like the charge is controlled my Q3 and Q4 and I doubt it is very precise and I also doubt there is any charge termination.
If you had provided a photo of the other side of the circuit board also, it would have been easier to see.
Would you use these chargers or recommend them for the general population? Really, thats the question isn’t it?
No, I believe they look to much like the cheap usb power supplies:
But due to the 110 VAC, the safety requirements in US is considerable less and it might pass.
So it seems the first chargers I received from T-Mart would be better suited to use than this second set. I would definitely charge up to 4.2v on another charger first due to the slow 350mA charge rate on that first charger. Ugh - thought I had a good solution going.
-Garry
Tmart one, post 19
Could you take a picture of the markings on the blue capacitor (marked “CY1” on the pcb) and a picture of the other side of the pcb?
Ok, but you will have to wait as I don't have it with me right now.
-Garry
