Review: NANJG 105A 2800mA driver
- is on the solder blop left to the second 7135.
Ouch, that mistake made me feel foolish. And because the driver was such a tight fit(even had to sand it down quite a bit), I can't remove it from the heatsink now. I think this light will have to remain a 1-mode until I get a hold of something thin and solid that can poke the driver out through the holes where the wire goes to the LED.
Thanks for clearing it up for me.
You might want to change your graphic or delete it so someone doesn't get the wrong idea. It's true that the negative connection is the pad on the upper left next to the 7135.
Nice call - It's gone now :).
I managed to pry the driver free from the host, and now everything works as it's supposed to. I have to get used to the memory mode, though.
Thanks, I was also in doubt for a while.
guys, I have lost the C1 on my 105C, probably got ripped away while modding lights:( does it affect something? do I need to replace it (if yes, with what capacity)?
It's just a buffer cap for suppressing noise on the MCU's voltage supply. These caps are usually in the 10nF - 100nF range. The driver will probably work without it, but you might see some random erratic behaviour.
Does anyone know the difference between NANJG 105A & NANJG 105C
http://kaidomain.com/ProductDetails.aspx?ProductId=10995#
http://kaidomain.com/ProductDetails.aspx?ProductId=1770
It seems that 105A kept changing for a period.
The price difference is quite high, for 2 x 105C I can buy 3 x 105A , and I want to buy a 2-3 of these.
Is it possible to buy 105A and get the 105C ?
I don't think they make the 105A or 105B any more, I think it is 105C only now. I believe it is like a revision letter. I hope the 105D comes out soon I have been getting some bad 105Cs lately.
Now the links are working.
Then why the $2 in price difference? 105A appears available, check the first link.
What do you mean bad 105Cs, not working or, you have to clean the solder....?
Got some bad non working ones in my last order, mode issues.
Your links don't work.
Still not working ?
SKU: S009742 vs SKU: S004338
Nothing worse than a bad C to leave a lousy taste in your mouth.
OK so far the difference between the two NANJG 105's :
SKU: S009742 $4.7 Product added on February 24 2011 http://kaidomain.com/ProductDetails.aspx?ProductId=10995#
SKU: S004338 $6.63 Product added on April 5 2011 http://kaidomain.com/ProductDetails.aspx?ProductId=1770
Which one have you guys bought? I asked if anyone knows the difference, but I guess that's going to be hard to answer to.
I have bought tons of the 105Cs. Take one for the team and order the other one so we all know what it is.
I've bought the $4.70 one several times. It is a good board with different mode groups available. The more expensive one (from the pictures) doesn't seem to have a microcontroller, so it *should* be a 1-mode 2.8A board (one of the reviews indicates it has modes, so either they are shipping something different or the review is for the wrong product). The second one may have a 2011 date, but the reviews go back to 2009.
Thanks guys!
I bought a few 5 packs (alot cheaper) and worked fine. I managed to kill one of the amc to get 350mA less draw for a comission speciality flashlight and the owner was happy for the added runtime and less heat and not much less output. At least not easily percieved drop in brightness.
You mean, a few 5 packs of the 105C, which are alot cheaper as the Kaidomain price? Do you have a link?
It's this product http://kaidomain.com/ProductDetails.aspx?ProductId=10995
just that here you buy 5 pcs
http://kaidomain.com/ProductDetails.aspx?ProductId=11088
If you buy 5 of the first link you pay $22.15 (that's the price for 5+)
But if you want to buy the 5 pcs pack you pay $21.79
