6x SRK modded with 3 terroid driver, successful. (beamshots now included)
Just a quick note to say that the 3 terroid SRK driver works fine powering a 6x. I bypassed the 3 15k resistors they are marked 153. On these resistors the third number is the amount of zero’s. So 153 is 15,000. 154 would be 150,000 and so forth and so on.
If you have this driver and want to up your amps it’s a fairly simple mod to do if you have a soldering iron and very steady hands. There are exactly 3 of these tiny resistors on the driver. One is under the terroids but they can be carefully moved out of the way. You can replace the resistors to ones with less resistance or do like I did and simply solder a small piece of copper wire from one end of the resistor to the other to bypass the resistors.
This along with a tailcap spring mod and heavier wires doubled my lumens. I also de-domed the emitters and put them on sinkpads while I was at it.
Well where’s the beam shots or it didn’t happen. :stuck_out_tongue:
Sounds like a great improvement 18sixfifty. If you have a kung I would love to see a comparison shot.
Thanks for the info.
I’ll post some later tonight for you. I have a few things to do and batteries to charge. I have a stock uniquefire 4x XM-L2 with a great reflector from wallbuys that I’ll take pics next to. It hasn’t gone under the knife yet.
Waits for Beamshots
do you have another SRK to compare it to ?
No sorry. Nothing remains stock around me for long. I’m an modding addict.
i hear ya. my “stock” lights are dwindling too.
Ok the first two pics are the Kung on low and high
These two are the modded 6x on low and high
My neighbors house, work in progress, nobody lives there. If anyone knows how to do the mouse over thing feel free to give it a shot. I have tried a couple times and gave it up.
Kung and 6x oh and both lights had the same freshly charged 2,200 sanyo's in them.
Mouse over like this ?
Sweet thanks.
