I dont like hardware possibly scraping my lights.
I usually remove metal fixtures and attach just the actual paracord to the light when possible. I use asmall split ring in cases where the lanyard holes are too small to
feed paracord through.
Yeah, when they arrive for me I’ll slide them through the lanyard hole then pull it through itself so I have something to grab a flashlight out of a pocket etc. and being bright colored they might be good for helping you to find your torch/knife etc. if you lost it. They’re just little things that you always needs for knives and stuff.
When I see all the erm…… stuff that gets sold for cheap it makes me really pleased that I bought mil-spec 550 Paracord and fittings in A2 and A4 stainless steel.
Please, learn to tie a knot and make your own or buy from a reputable maker, Essexman maybe.
You’ll curse the day that you bought these “lanyards”. How much is the knife, light, bunch of keys etc. worth to you. Imagine them sliding down a drain when the cheapo connectors part company, If you’ve ever lost a key this way you would never buy cheap paracord again.
Knockoff paracord isn't that bad, not for this application, but I'll agree that the hardware is rubbish. I wouldn't use the hardware even if it was good though because I don't like how it tears apart the anodizing around the lanyard hole.
The cord end is another weak point. If you make your own, connect the cord with a couple stitches before installing the cord end.
Good quality paracord is much better to “tie” and the finished pieces look a lot better. but as you say in an application where you’re only holding a couple of dollars worth of kit then fine, I just wouldn’t want to see car or house keys disappear.
I bought paracord in the USA two years ago from Supply Captain and thsi was really good, but shipping to Europe was expensive. Now I buy here in Germany my paracord.
A needle could be also fine to work with, but I haven't one.
I Germany it cost round about 6-7€ + shipping (in US round about $5).
Is it important to have a brass needle or is aluminum similar? Some shops write, that brass should be better - I don't know why?
Brass feels better, a bit more slippery, but it’s probably all in the head. Aluminium and nylon should be just as good as brass and nylon on the friction side. brass might have the edge in retaining the internal threads.
Personally I’d prefer the brass but either would do fine.
