I have http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led-flashlight-with-strap-black-1-x-18650-57097 ordered 19/3/2011. I just received the same light ordered 25/6/2011. It came with different reflector, different dropin, few scratches and some batteries (3 of 4 blue trustfires) will not fit (battery tube has much smaller diameter).
You need a flashlight without the stupid flashing modes. With these modes you have to get past the strobe and SOS every time before getting to the high/mid/low.
Welcome to BLF Biker. For a cheap Bike Mount look here and you can use it with hugsby p31 my favourite aa bike light also take a L2 clone with 18650 for more information look here. For 18650 and charger look at BLF.
So many suggestions, I’m losing the overview…
The C88 would be just fine. Is the light so worse compared to 18650?
Any alternatives with normal batteries?
I don’t mind discussing a good red tail light.
I’m looking for a basic one. So I can almost buy this every where. Or are there any detials I have to check? Any recommandations?
Is there a beam shot of the Q5 in the forum?
A tight hot spot isn’t really suited as a bike light.
Is there a good alternative to the C88 with a bigger spill?
I really like your self-made superbright tail light.
But for my purposes (mostly of-road with no traffic around) a cheap or engineered model will be sufficient.
Can you show me examples for both?
Thanks for your replies.
@ Be-Seen Triker:
Is it difficult and/ or expensive to mod the C88 to an XP-G R5?
What will be the batteries’ run-time with this mod?
I would be happy to get you help. But the additional shipping costs from the US to Germany are probably to pricey.
Well, normally I’m handy with tools.
But I have not worked yet with such small electrical parts.
Can you explain what is exactly to do? Maybe you have some pics of such a mod.
It would be most easiest to get a C88 first and then to decide if a mod is really sufficient.
But as the C88 has a small pill only, I’m quite sure that mod will be necessary.
Is the C88 available any where else (cheaper) than @ Manafont?
And where should I buy the XP-G R5 dropin and the required heatsink glue?
Sorry, I meant the spill.
The spill will get comparable to a 18650 after the mod?
Beacuse that is the most mportant thing for me.
Hmm, I haven’t soldered yet and have no soldering gun.
But a friend of mine has one a could help me.
Thanks for posting the links. Looks very inetresting and you seem to be adept in modding.
So what do you think costs shiping from your side to Germany?
If you're going to mod this light use this emitter .. much much nicer tint .There's no reason to mod a light using the same stuff every manufacturer uses .. put the better tint in while you're doing it. It will make the light stand apart from everything else you have .
Shipping on all of these items is free worldwide ..
If you are interested I have a lot of lights that my brother likes to borrow. We downhill mountain bike and trail ride so we need something bright and strong. So far this is the setup he likes the best and it fits your budget.
The KD C8 seems to be the best bike light for the money. I had to buy one for him because he kept taking mine.
