MTG2 6V variant can be direct drive from 6V or still requires 8.4V? .....please help....
Since the MT-G2 (on a copper board, when heatsinked) will not blow at any current below 16A, you can experiment with almost every battery configuration that outputs more than 6V
Just make sure you put it on a copper star and you’re good to go.
That is the fun with the direct bond to copper (available to a layman like me since the Sinkpad came out :-) ), it almost doesn't matter anymore how small and hot your flashlight is: the led just keeps going.
Thanks to you guys here 8)
I just purchased the TitaniumInovations 3AA to 1D cell holders. 2 of them to be exact. I got the series variant, so each one will give me 4.2V~4.5V input. Effectively putting me in a perfect spot to overdrive this LED.
Now, I have to re-think what 2D cell host can be made into a twistie rather easy….lol
Best,
bigC
That sounds like it will work very well. Could you please give an update when the mod is done (with pics of course )
I want to have it take both AA with holder and D cells.
Since I will most likely have a buddy build me a 2D Mag Host with copper slug heatsink I think those two 3*AA holders will work great as a AA cell alternative.
I was thinking since I have a dozen NiMH D cells that I can purchase some D cell extentions. It would look like a 70’s 6D or 7D Mag….lol
Does anybody know for certain if I can even do 7D NiMH on DD ? Thats about 9.8V input when cells are fresh off the charger, but they very quickly get to the stable 1.2V input each. So, would you guys even try 7D cells or stop at the safe 6D cell configuration?
Thank you,
bigC
Only one way to find out... (would be easy to say that if the MT-G2 wasn't so expensive!)
The MT-G2 with a good thermal path can take quite a bit of abuse and draw a lot of power! My guess is that it is going to suck those cells down to a reasonable voltage quickly with the amount of draw it is going to put on them. It may be safer to try 6D first and see what voltage sag you get when turned on, then you can decide whether or not 7D is a good idea.
Be the first, we are all watching. Seems a little high to me.
Just a quick update.
I went to AutoZone and purchased a $33 dollar 6D Flashlight. Almost identical to the homedopot Defiant 3D in terms of heatsink screwing out and incredibly easy to mod……
The 6D from Autozone is rated at 200 lumens via an XP-E emitter and its a 20mm star. So, the 20mm star MTG2 would fit like a glove.
The reflector is plastic and the Lens is too. Fortunately my UCL Mag Diffused lens are exactly the same size and it fits perfect.
The stock driver I am not sure what it is. But the XPE pulls .525mA at the tailcap with 8.4V input. So, thats pretty good 4watts~<.
Hopefully, I can finish the project this week and post results.
bigC
6D vs 3D
I couldnt find the 6D light on autozone.com. Is the heat sink as thick and heavy as the 3D defiant? Im looking forward to your mod pics. I bet this would accommodate 4 x 32650’s.
it should, may be even 5.
i’m thinking that light, mtg2 and b3 flex, or hb flex if mtg2 is 36v. should be very bright.
i recently build mtg2 4c mag, with deep rebel reflector, but i still had to use difuser film, cuz beam was full of artifacts. regular inc. mag reflector did not focus mtg2 at all. b3flex offers temp control, if glued to same heatsink as led.
I found the 6D: http://www.autozone.com/autozone/accessories/Police-Security-Hi-intensity-flashlight/\_/N-25dr?itemIdentifier=554766_0_0\_
Im sure George could set us up with an excellent driver, but then we would quickly run into problems with heat sinking unless a much larger deeply finned one could be made.
Its hard to beat the bang for the buck when considering the super easy Trustfire X7 MTG2 mod. The large stock reflector takes advantage of the MTG2 and casts a fantastic beam. It would have been nice if it came equipped with a 26650 or 32650 battery tube, but it already does well on its own with 3 x 18650’s.
I’ve been eyeing that light for MONTHS with that same thought. It would almost be like doing the same mod to a 6D Maglite. But without all the fuss and expense of trying to find an appropriate heatsink. I’m sure that light would be AWESOME with an MT-G2 and six Tenergy Centuras or Premiums. I’m just surprised nobody has done it yet. But I guess most people would prefer to do smaller lights powered by Li-Ion batteries. By the way, do you know what the driver size is in that light?
Speaking of Li-Ion, I wonder how an MT-G2 would do with a couple of A123 Systems LiFePO4? Voltage would be lower than with two IMR or ICR batteries. But with those 70A 26650s, voltage sag would be practically nonexistant - a constant 6.4V throughout the entire discharge. OR, add another for 9.6V.
Just an update. The driver in that big 6D Light is beyond me. It looks like a normal 16mm P60 type drop-in.
The heatsink while it screws out, to my surprise it is completely hollow. No heatsinking even below the emitter. Weird for sure.
Anyhow, PCC here is helping me with a copper slug for the center. The 6V MTG2 off my initial testing only pulls 1A off 6D Tenergy cells. Not sure whats going on there.
I think the switch has a lot of resistance. I’ll have to come up with something to replace the stock switch as well as to increase the heatsink mass.
This 6D Light while it has a screwout heatsink that is easy to mod. The lack of heatsink is not good at all.
Having said that, the beam it produces stock on its factory XPE is utterly amazing. Perfect round and white beam for wall hunters.
I like this light so much I am debating on purchasing a 2nd one. Just drop in an XPE2 and run it with stock low amp driver. Yup, it still throws amazingly well for a stock low powered 200 lumens light.
bigC
It’s just that it’s so dang big. It’s like carrying a baseball bat around. Maybe that’s why you like it, but, it’s just massive for that 200 lumens.
The holdup on your MT-G2 version is the switch. The stock switch is pretty cheesy and will melt when we turn it on with this emitter.
I was about to say get ready to heatsink the snot out of it at that voltage and output
Tons of light because you are now holding a small sun! 2000+ lumens from ONE emitter! Whoah!
