The little black one up top is practically worthless, would like to know where to get the gold metallic one below, especially if you can disassemble or get to the pill easier
Then possibly one of those 13mm 550mA boost drivers from FT and a 14mm XR-E (saw some 10mm ones on DX.com or 13mm at FT)
Wallshot with that little emitter is a bit brighter than the stock led for sure...but not much
I guess they would be useful if it was pitch black and you had nothing else available...
I have some of the above drivers inbound, was going to tweak out a Sipik SK68 clone for AA only (since it pushes a little bit more juice than the booster/regulator AA/14500 one) and going to swap out the emitter as well, just to play with em and see what I can squeeze out of it with only a 1.2-1.5vdc battery, with a 14500 it is quite bright (for a "bic lighter" of zoomies), but get's hot and chews thru a charge in 40-50 min
I’m eventually doing something similar with a lowes side clicky cheapie using XML TIR, xpg2, and the tiny AA boost driver from FT. Not a pocket rocket, just a functional AA light with decent output.
I definitely like that golden yellowish police light more than the other police one.
800mA with those kinds of modes would definitely be a good AA type booster, any of the PCB guru's want to reduce one down to a 15mm or 13mm die size? (in fact I will buy and have one shipped to the PCB guru's to strip it down so they can build it...seriously!)
I have put these drivers in various lights including Sipik SK68s with XM-L2 emitters, XP-G emiters, etc. its also a regulated driver.
My current EDC in my winter jacket has a modded SK68 with this driver and a Neutral White XR-E in it. it has the best output on High from a single AA eneloop as any single AA light, while having a great firefly mode that runs for days, and even a Beacon mode. and another good thing about this driver it has almost no PWM, only on low and is if a high enough frequency not to be anoying.
Avoid 14500s though, it heats it up very quickly and may burn it out.
I have 2 black ones. One had a strap hole drilled into each end of the tail cap so it can’t seal. The other went out after a minute on 3.7V and I thought something burned out. Nothing fried but I notice yours has a big spring that mine doesn’t. I just soldered some wire around the bottom. I’d buy the gold ones next time.
I modded one exactly like the gold one but with black colour. Baked to dark brown. Used similar 119 emitter, but for the driver I simply used 2x 7135 and run with 14500.
As a finalizer, I put a clip from $2 wallbuys light and glued in a couple of magnets.
The result was excellent. I just love these cheap lights for tinkering.
Did a 17mm fit? I know AA are 14mm in diameter,unless you did some serious reducing of the diameter how did you get them in there, the Sipik’s are 15mm if I am not mistaken
I am going for a AA only booster (not 14500 regulated) this is my test to see what we "can" squeeze out of AA sized pocket lights with just an AA (how many granny birds or people you gift these pocket lights even know what a 14500 or how to properly handle a Li Ion)
That 800mA one is definitely the highest powered boost driver I have seen, however it's a bit too big for most of these teeny pocket lights
Umm… by 2x7135 I mean literally 2x 7135 chips. No 17mm board involved, no controlling IC, just straight single mode 700mA limiter.
The two 7135s - I soldered them together on the legs and wire them up direct to battery and emitter. I still use the original driver board, just clipped off the components to remove the big (by comparison) stuff.
To prevent shorts I just wrapped the 7135s in kapton tape, though any insulative method can be used.
Well, good luck with your boost driver experiment. I simply took the easy way
