Thinking of making a P60 drop in for a 2x 18xxx host with a USB port and one or more stacked (maybe even a single mode board) LD2981 voltage regulators to use as a portable USB charger. The chips are sot-89 packages with 100mA max output and have the same I/O/G pins as a 7135. Work/won’t work?
Most voltage regulators don’t like to have their outputs paralleled…
:_( so 100 mA max. Could you explain why or is it over my play grade?
Have you searched ebay for step up/down modules, there are a a lot different ones out there
In many cases, you can buy entire step down switching circuits on ebay for less than the cost of just the ICs they run on from someone like Mouser or Digikey.
I have some of the regulators and thought I might be able to use a few this way. Any of those step down modules fit in a p60 head w/room for a USB port?
Probably, there are a ton. Many shapes and sizes. Many will have USB ports right on the circuit board for exactly this purpose.
