What is the standard charging setting, after plugging it in.
The low end voltage for 4.35V batteries makes me a bit sad, are you sure that it is only a matter of production differences or have they adjusted the voltage a bit low to be on the save side?
Do you plan to review the new sample of the LGD1 which is in your picture…?
That seems awesome but then you put this comment above…
“Before using the charger for a 4.30 volt cell I will strongly advice to check the charge voltage with a DMM: Connect a DMM parallel to the battery and check that the voltage stays below 4.35 volt all the time while charging”
@hkj
I already have seen the review of the LGcell, but I asked if you will also test the one in your picture which is a newer version. I wonder if they have changed something internally too or just the shrink wrap…
New:
I'm a bit late to the party but I just ordered one from Mountain Electronics. It looks like the perfect travel charger with very decent features. I should have it on Monday
Thanks :) I have 4 other Xtar chargers (WP2, MP2, and 2 VP1's) they've all been great. I like that it's small and does 4.35 volt cells which I have, and the USB output will sure come in handy every once in a while.
I will be receiving an XTAR SP-1 that I won for $16.00 from a dealer with few reviews on Ebay, and half of those for clothes (or scarfs), called xtarshop, do I have to worry about fakes?
