Nice, I see that light around quite a bit and would love to pick one up for that price. I didn’t know you could put an SST-90 on a MT-G2 board, thanks for that. I have a couple de-domed ones laying around. Now I might just get to playing with them.
Have you considered de-doming that emitter? It really does help throw a ton and they are super easy to do. Let it heat up and it will pull right off.
I don’t find it too bad, the head gets really hot on high for a few minutes but the handle is not too bad. I run it mostly on medium and find that sufficient anyway, with high as a turbo mode. I love the big hotspot, and it throws like hell. Wonder how many lumens its putting out. I’m getting over 8 amps on 2 kk’s. It’s a beast. Glad I bought it. Thanks O-L.
I just picked up a TR-J10 and I’d like to soup it up like you did. How did you get the driver out? Mine has a brass ring holding down a white nylon disk which I presume is pressed up against the driver. There is a brass cap screwed into the center of the disk which covers (and compresses) a spring. There are no slots in the brass ring to unscrew it, so I assume it is press fitted. The ring does have a lip around the inside which I can slip a screwdriver under, but it doesn’t want to budge. Do I need to cut it out? Or is there at better way?
I couldn't get that darned brass ring out at all. I finally used a small chisel and broke the brass ring, so it would relieve pressure and then I pried it out. I replaced it with a home made copper ring.
EDIT: I could have beaten the driver out after taking out the led, but I didn't want to hurt the driver.
