I don’t find it too bad, the head gets really hot on high for a few minutes but the handle is not too bad. I run it mostly on medium and find that sufficient anyway, with high as a turbo mode. I love the big hotspot, and it throws like hell. Wonder how many lumens its putting out. I’m getting over 8 amps on 2 kk’s. It’s a beast. Glad I bought it. Thanks O-L.
I just picked up a TR-J10 and I’d like to soup it up like you did. How did you get the driver out? Mine has a brass ring holding down a white nylon disk which I presume is pressed up against the driver. There is a brass cap screwed into the center of the disk which covers (and compresses) a spring. There are no slots in the brass ring to unscrew it, so I assume it is press fitted. The ring does have a lip around the inside which I can slip a screwdriver under, but it doesn’t want to budge. Do I need to cut it out? Or is there at better way?
I couldn't get that darned brass ring out at all. I finally used a small chisel and broke the brass ring, so it would relieve pressure and then I pried it out. I replaced it with a home made copper ring.
EDIT: I could have beaten the driver out after taking out the led, but I didn't want to hurt the driver.
OK, I ended up using a dremel and a chisel to cut through that brass ring. It wasn’t pretty. My driver has that same tiny R300 resistor that you have, so it must be factory. Do you remember what size resistor(s) you ended up adding?
