Digging the look of that driver. Kind of Borg meets flashlight driver. Your work is a little over my head right now, but it seems to be going in a great direction.
Works fine this time. I guess the first try with the stock MCU(-thing) still on the board did something weird to the signal. Just bridging the big sense resistors gets over 4A per channel, I may be sane and boring on this one and just add resistors to get it up around 3.2-3.3A each.
PWM wire connection onto the SRK board:
This is just like the master-slave thing with multiple 105C boards, only using various different hardware as the slave instead. And the momentary switch firmware is what I didn't have to do this stuff before.
I'm afraid to try one and find out it's not as good as the ones I already have... :~
HA, 70N02 does 4.34A, single XML2, single 20R (two 20Rs=4.62A, 3=4.78A, 4=4.86A). Works fine connected straight to the attiny. Bypassing the FET (short drain to GND) with the same single cell/LED gives 4.45A. So it's a good'un. :party:
And YES, adding the toroid makes the low much much lower. I checked by jumping across it while running in various modes. Makes barely any difference in higher modes but affects lower modes A LOT.
Good info in this thread comfychair.
I have some of the 70n03 FET’s from this thread recommended by moviles2. East-92 4amp 17mm driver.
I have tired to keep up with this thread from day to day and I guess I keep forgetting the day before. Getting old sucks.
I’m going to have to go back and read this all from the start. Maybe once your done comfychair, maybe you could make a “How to” or a “guide” to help forgetful people like me.
Nice work you have done here, thanks for sharing.
Sense resistors bridged, it does ~4.3A per channel. The copper bar isn't a ground bus like the stripped-down version, it's just there to mount & ground the 105C.
1. The toroids help achieve a lower "low" mode, correct? Are you using lower driver PWM settings to get this, or with the same PWM setting is the low mode lower?
2. Where can you buy toroids like these? (Besides harvesting off of existing drivers ;-) )
Love the way you modded that traditional SRK driver. Do you plan on using DrJones MiniMo on it? What is the lowest PWM value you think you can get to work on this rig?
PWM of 1, with a toroid, gives a hilariously low low. Won't even register on the meter. I haven't done a new build of the firmware to compare the low numbers, but Werner's is using 7 for the low, and even with the toroid it's too much light to really be called moonlight. 1 without the toroid is fairly low, but still not moonlight really.
I don't think the uH rating on the toroids matters much, just that there's something there, and is able to carry enough current to not be a restriction in the higher modes. A little bit of resistance drops the current a lot with the single cell input voltages. To be small enough and carry enough current, it's almost got to be one with multiple conductors, I think. Small number of turns you get with multiple conductors on such a small core seems to work fine. These were harvested from old motherboards.
We're working on nailing down a readily available toroid that ticks all the boxes.
You have any thoughts on 70N02 vs 70N03?
Yes, it has higher on-state resistance (.0051 vs .0042) and much much higher gate charge (90nC vs only 40nC), which means a tiny13 would probably not be happy driving it without extra components added in that nobody wants to mess with (gate drivers).
If its easy and simple to explain, what does the Torroid do?
Magic, would be my guess.
According to Wikipedia, it's like a resistor when current is changing (like, a PWM signal that's on-off-on-off), but a plain conductor when the current is steady. Or something. I think magic is probably a more plausible explanation.
This is the old-style SRK driver, MiniMo, PWM of '1':
That's much brighter than in real life, the camera's trying its best to find any available light.
Frickin cool. I haven't seen any srk or triple emitter deliver a decent low, let alone a moonlight. That looks like a firefly mode or something. Very awesome.
Thanks for the responses above Comfy. Much appreciated.
Red 'JB' driver, 70N02, toroid, MiniMo PWM=1
Werner's 098b (PWM=7), toroid, 2SK4212 FET, left; MiniMo (PWM=1), NO toroid, same 2SK4212 FET, right:
Much shorter exposure on the second pic, the background lighting was the same for both pics.
the geek speak hurts me wee head. I beg of ye, please create a how to/info post on this thread, explaining in everything in plain engrish so us mere mortals can understand.
I have no idea what you have done, but if it makes an srk usable, and is budget-ish, I will take a hundred of ’em
The microcontroller, whatever it is, on the SRK-style drivers isn't reflashable, at least not by us. I'm sure somebody somewhere can do it, but I don't even know what the chip is.
The stock modes & UI suck. We can write and flash out own programs for the chip used on the Nanjg drivers, the attiny13a. This is just using a Nanjg driver's controller to run the driver hardware on the SRK-style drivers, with code that works better than stock.
Strip off all the 7135s from a Nanjg 105c, feed it power & ground like normal, then run a jumper wire from the 105c's PWM line that used to run the 7135s over to the spot on the SRK driver. The 105c's brain never knows anything has changed and just does what it's programmed to do. The SRK's driver controls the current to the LEDs, and it never knows it has been given a different, alien brain.
Werner's firmware is: Short press ascends from low to high, five levels (and one level at 0%, which is 'off'). Only turns off by cycling back around to the 0% level. But, a long press descends through the mode order, from high to low. So, with the light off, a short press followed by a long press, turns on in the lowest mode, and then turns off. And a long press followed by a short press turns on in high, and then turns off.
DrJones' MiniMo is similar but has a long press for on/off, and a short press ascends from low to high. Has memory so it comes on at the level last used.
Thanks comfychair. I could understand your last post. It makes more sense now.
