Tmart Group Buy - GO TO THIS THREAD TO SIGN UP - http://budgetlightforum.com/node/29665
avoid if you dont plan to mode it, hollow pill and garbage driver, also no room for protected cells…
How about small EDC LedLenser P3 :slight_smile:
If I went with a HD2010, it would be the FandyFire. Better light (at least the one I had was very good), and in black too.
I also like this light. I believe it's a C8 reflector, but in a HD2010 style body.
and that X9 sure does have a hollow pill, so it would be harder to mod it. I would like to see the insides of the Ultrafire V2 as a thrower.
Overall, so far, the HD2010 has it as the most talked about, so we will see if that changes any in a couple days or so.
Black is fine with me, Im not a ‘luminist’.
No idea on model though. Ill have to take your word for it. Although, 2.3a is a bit low isnt it? Or am i missing something? I would have thought XML2 would be desirable too. I have lots to learn.
I'm buying it to mod, so driver and emitter aren't a big deal. Quality of the host is a big deal.
We are talking stock lights here, not modded ones, so they come with XM-L T6 in all of them. There won't be any changes made by tmart, they just aren't into doing that kind of stuff. It is what it is. I've talked to them enough about that.
They have the Fandyfire HD2010 listed at 2300mA, the No Name HD2010 listed at 8 watts, so basically 2300mA most likely and the Tangsfire HD2010 listed at 6 watts, so that should be less than 2300mA.
Actually, if I had to pick anything, it would be this light. I just think it's sweet looking, because I favor smooth lines over all the medieval bumps. I think it might be an ok thrower.
Ah I see, thanks. I had read the bits re no modding by tmart and was cool with that, I want to mod it myself to learn on. But I had not realised that it wasnt available in XML2 nor in 2800ma. That last one surprises me most as I see that number talked about in much smaller flashlights. I either assumed, was confused, or both.
As I said, I have much to learn. Cheers.
Actually you got m interested in this one. But I must not, I ordered enough lights i have no real explanation for already. I can justify the HD2010 as I bought the pill, it would be wasteful not to use it. I cant justify the pill, but that was only $20 so is much easier to get away with. :smiley:
The driver current specs could also be wrong, unless I’m overlooking something. If you get one with the ‘good’ driver it will vary drastically based on which battery you use. For instance, that tangsfire version is listed at 6W, but people have reported well over 4000mA on high drain batteries.
Isn’t the East 092 driver direct drive, both the FF and TF versions I have have that driver. Quality of both is the same.
One of the lights I wanted but never bought was the Ultrafire 980L , always rated highly. Maybe they could get some of these.
HD2010 is a good light if the price was to be somewhat less than they list it for.
HD2010 is a great light but they always run them on special, picked up two TF versions from them in December and January for $23.48 and $22.49. Why waste a group buy on a light that’s always on special. Tangsfire and Fandyfire are equal in every way.
But which one. Browsing the link provided by OL I think I counted 8 HD 2010’s.
I like the looks too, better than the hd2010. But personally I don't care much for 26650 flashlights, it makes the light fatter than a 18650 model, and the 26650 batteries are not as much better as they are bigger.
There's two hd2010 lights at tmart on special for 25 dollars, so not much gain on those with a group buy I guess?
Plus 1 (I like the looks) :wink:
2nd choice HD2010
I don’t know, all the ones I see are in the thirties, for pricing. I don’t see anything priced in the twenties for the 2010.
He is in Amsterdam.Could be a currency rate thing,the dollar is a little low.
I have had enough HD-2010s, even had a couple from Tmart.
How about a UF-2200 ?
Silver or black, 26650 or 18650, C8 sized workhorse.
Previous discussion thread here: Cheap U2 XML single cell 26650 lights
Ah, I see now, sorry : http://www.tmart.com/search.html?q=hd+2010 gives prices in euro's, the cheapest is 24.56 euro and that is over 30 dollars, my mistake
To bad it has to be only Tmart i would go for the XinTD X3, but so far i like the Prairie fire D11
At this point, the majority seems to lean towards the HD2010. I can understand the desire to have one or more than one, as I need two myself, but I can also see the negatives. It does go on sale often and there is the driver lottery with it.
The rest seem to be hit or miss, so I am going to say that the HD2010 will be one that I ask the Tmart rep about.
How does everyone feel about this light? BeamTech BT-950L It has been reviewed at BLF here.
No one selection will please everyone and the majority will rule in the long run.
