Originally want an iCharger, ended up with a Thunder AC680
Nice price, but no stock in their US warehouse.
Dont like their Intl warehouse? Apparently it has stock… hobbyking.com.au
It looks like they have the 106B in the US, but I assume you knew that.
Their international warehouse has plenty of stock, but I don't want to wait for this order, and I really don't want to deal with an international warehouse if I need a replacement.
There's another vendor that I emailed yesterday about getting a better price on the charger and a power supply. There's someone in Santa Monica selling a used one for $70, but driving up there would use too much gas.
Progressive RC in Seattle is considered to have fair prices and customer service. They seem to have stock of what you are looking for.
They also list several charger+PS bundles.
I can also recommend, http://www.progressiverc.com/
and also, http://www.buddyrc.com/
and if you are like me, and like modding stuff, I can also, whole heartedly recommend a modified HP DPS600PB to use as a power supply. You can get one on Ebay for near $10, and all you really need to do is jump a couple of wires to get it to turn on, slow the fan speed down by jumping one more wire, and BAM, you have yourself a perfect 12V 47A power supply.
I have been using one running my hobby chargers for years now, and it’s been perfect. I took my power supply one step further, and hooked up my 2 input wires internally to the screw terminals, and put some bullet connectors to match up to my charger input wires. The pins you have to jumper to get it to turn on, and turn the fan down, were done internally by simply twisting some wires together. Very easy to mod, and a super rock solid power supply.
Buddyrc hasn't responded to my email, so I'll probably go with someone else or even another charger if I can't get it for less than $140.
That server power supply is a possibility.
When did you send the email? Yesterday was a holiday. :~
I had one problem with buddyrc, and they took care of it pronto. No questions ask. Really good customer service both in emails and over the phone. This was a $150 charger. Sent Me a replacement as soon as the bad one was dropped off at the post office, they had sent me a printable shipping paid label by email. The also had a 10% off coupon I took advantage of. I would highly recommended them. Sorry if I sound like a darn salesman. :zipper_mouth_face:
I have also heard very good things from Progressive RC. Those two would be my top pick. Either one will handle in warranty claims very professional.
I use a Xbox360 power supply. 12v 16 amp output. I had one that was just laying around taking up space.
It was yesterday. I'll give him until some time tomorrow and I'll place an order.
My fallback is probably going to be the AC680 from Hobbypartz. They're closer to me, so shipping should be quick, but I'll have to pay taxes. It's not as nice as the iCharger, but it'd get me going. Later on I'll build a serious system for balance charging and testing a bunch of cells at the same time.
No luck finding a used charger and I didn't hear back from Buddyrc after two business days, so I went with Hobbypartz. I'll go with progressiverc when I go for a hobby charger.
Good choice on the Thunder AC680, you will like it a lot. You shouldn’t feel like you don’t have a true “hobby” charger, because you do now! I personally have had multiple Thunder AC680, a Thunder T610, and a Thunder 620 charger (hooked up to a 12v server power supply), and they have always charged perfect. Thunder chargers are really nice, and you made a good choice. I have dealt with HobbyPartz for many many years and have always been happy with what I receive. I am a BIG fan of Thunder chargers.
Don’t let people fool you into thinking that iChargers are some mysterious perfect super chargers that have no rivals. If someone was giving away free chargers, and I had a choice between an iCharger 206B, and a Thunder 620 charger, I would choose the Thunder 620.
You should have heard something back within two todays. I cant say as I blame you one bit.
Looks like you have chosen a good charger. I have heard a several good things about them and you will not have to fool with a separate power supply. Let us know how it goes leaftye.
@drdanke
You're right. It's definitely a hobby charger. This is an easy way for me to get started and a stopgap. Eventually I'll get something serious that can handle high current discharge and balance charge more cells. I'll work on getting or building a big power supply, charging cradles, and whatever else I may need. I'm glad to hear you've had good luck with the AC680 and other Thunder chargers. That's a huge relief because I'll be putting a couple hundred cycles on it within the next month.
The Thunder 620 looks like a very capable charger, but I'll be doing lots of logging. Hopefully they'll update it soon because it's a great value.
I'm looking hard at that HP power supply. That's almost certainly the way I'll go.
@moderator007
I like the xbox power supply idea too. There's a guy selling one locally for $10. I'll see if it's still available. Having a backup isn't a bad idea, even if it means charging at a slower rate.
I'll definitely give some feedback. I'll be working it hard, so you'll hear from me soon if mine is unreliable.
This is how I have mine setup. I took it apart and rewired it with some 12 AWG silicone wire and soldered on female banana plugs. There quite compact for the amount of current they produce.
Can you control the iCharger from the PC?
Or is the PC connection only for logging the incoming data?
Hmm . . . care to share what you're up to? Just curious. Sounds like some big plans.
-Garry
I use logview, and as far as I know its just for data logging.
Thanks 007 that is good to know!
As i understand Logview is not even coded by the iCharger makers.
Given the comments placement in the post I assume you are referring to the PSU, seems likely given kids run the xboxes they power for hours on end, doing whatever it is MS thought needed 16a, they should handle load alright.
Charger hasn't shipped yet. I was hoping it'd arrive quickly because hobbypartz is close, but that's not going to happen now. At least I didn't waste my money on a more expensive shipping service. I can't really complain though since they're website says products ship 1-2 business days after order. This is day two, although I ordered near the end of the business day. UPDATE: just got a shipping notification.
That's a lot bigger than I thought it would be, but totally acceptable given how much power it puts out.
I just ordered a server power supply. I still want a xbox power supply since it'll be far smaller and quieter, probably more reliable, and am keeping an eye on them locally and on ebay.
Soon my friend, soon.
Bad wording on my part. I meant the Thunder charger. I plan to keep a fan on both to keep them cooler and healthier though.
Which server power supply did you decide on?
