did he remove the original MCU and hook in there similar to what you did to the SRK?
Brian
Brian
Are you still using the momentary switch. I cant see one connected to any of the pins on the attiny13.
Switch wires are connected to the underside (black+red twisted, you can see them heading off to the left out of frame) so as to not block access to the MCU pins for reflashing.
Ah, good idea. I think I had mine hook to one of the stars, seems like it was the last one on the right.
I guess it depends on which one is used in the code. I’ll have to go back and get a little refresher coarse in how to make lower modes, the one I have only goes to pwm 5 and it has a few more lines that reference that value.
One more thing comfychair, have you looked at your joined date and your post count. Wow!
Yes I have used this on my M6 that’s how I came to the idea of using a nanjg as mothership.
I have stripped the original mcu and there was a special mode order necessary because the 7136 behave a bit different than a plain FET.
I guess you could try to use it with the stock mcu still in place like comfy first did, but I don’t recommend it for longer use because the standby current of the original driver is quite high….
Another one, this time with the stock resistors still functional.
Remove the stock controller, optionally place it on the floor and smash it with a hammer for proper disposal.
These are the 3 pins that go to the 3 gate drivers that go to the 2 buck controllers that run the 3 FETs. What an elegant design! :Sp
OCD? What's that?
See? Now they're mounted properly.
While still hot, smoosh the heatshrink down flat. Holds the wires in place tight enough that no epoxy is needed.
Power for the brain is picked up from the inboard tab on the big yellow capacitor (the cap's outboard tab goes to ground). The brain's ground comes via the copper mounting frame. The single black wire connected to the big driver's three PWM pins goes to any of the 105c pads that used to control the 7135s.
The only thing left to do is attach two pins to the back of the switch PCB, and corresponding female connectors to the ends of the switch cable. Makes disassembly so much nicer when you don't have to futz around with that stupid switch bezel just to remove the driver.
I measured L1=2.48A, L2=2.47A, L3=2.35A. All 3 channels have different resistor combos because of the vastly different PCB traces, but odd that the low one only has a single R010 resistor, while L1 has a R010 & R110, and L2 has a R010 & R068. Every one I've seen of this style has those same resistor values in the same locations, but I guess that's pretty close for a $5 driver.
yeah i dont plan on leaving the original MCU there. ill be removing it and smashing it lol.
i need to get a soic clip yet so when i do, ill be giving this a shot with my SRK and M6.
im excited.
Brian
Pretty snazzy! Any idea how many uH those toroids are?
The uH rating is less important than the current capacity, since everything that goes to the LEDs has to go through the toroid. Which of these would be least happy having 15 amps shoved through it?
I have not yet tried the little red one. Ones with fewer turns (less total length) or multiple or fatter conductors can carry more current with less resistance than ones with more turns or smaller/fewer conductors. As we know from selecting 'good' FETs, a few milliohms can make a big difference when the input voltage is so close to the LED's Vf.
The thing that has me stumped is, I haven't found any listings that allow sorting by number of conductors, and just looking through thousands of pictures on Digikey isn't really getting anywhere - everything I find that might be suitable is non-stocked. :(
You're right, they are all listed by uH (inductance) and amp rating. There are lots of stocked models on Mouser. The uH rating has got to matter, right? Isn't that the whole reason for using the toroid? Otherwise we could just stack a resistor with the same resistance as the toroid, but we know that the inductance is what's making the difference here.
Problem is that without an oscilloscope I have no idea how to measure the inductance.
All those shown have got to vary wildly in their uH ratings, but give similar results in calming down the lower PWM levels.
edit: Tested & working with a modified version of luxdrv 030b - ramping deleted, mode levels of 1,3,9,28,85,255.
Nice. I'm guessing the tab on the back would normally connect to a heat sink and ground. I take it, I'm guessing wrong?
Nope, not ground, the tab is for LED-.
G = Gate (the control pin/PWM pin)
D = Drain (negative wire from the load, here that's LED-)
S = Source (battery ground)
It goes between LED- and ground just like a 7135, except it doesn't limit itself to a fixed current. Whatever your cell can deliver is what the LED gets (minus a tiny amount from the FET's internal resistance, this one is around 0.0045 ohms).
Now that you say that, it does seem that the tab has an emitter wire on some drivers. Just seems like a good place to get the heat out. Thanks Comfy.
Yeah, glued on upside down with JB Weld, and flattening the legs and rebending them is probably a bit outside the intended design parameters, but you know... :evil:
At least it should be easy to solder a nice piece of copper to it.
It doesn't get hot though, on any mode. It might, in the other versions using the inductors since (I think?) in that setup the FET spends more time inbetween fully on and fully off, which is where FETs can get a little unhappy and start making some reasonable amount of heat.
A copper plate wouldn't help here anyway, since if the tab touches anything that could carry heat away the FET is bypassed altogether (LED- to GND).
Correct me if I miss something, but at say 5amps and an internal resistance of 0.0045 ohms, it will only generate 0.1 W, that will easily dissipate through the connectors.
