Thank you guys for your replies.
Now all I'd need is Thommy taking tail current readings in each mode with a fully charged battery, and again at a lower voltage.
Cheers!
Cheers!
You wil get them by tomorrow evening
On the other hand, there are really fatal decisions made on looks alone...
The fellow who won this bidding for $19.99 plus $13.49 shipping two hours ago, come forward!
usd33.50. Well done!
Awesome.
That's what competition brings.
That was me I think.
Congratulations, how2!
Thanks saved about $21, with that I can but another flashlight.
Only 2 seller were seller at this price.
You can get it for $38
$38 shipped is a very good deal too. It can be a very good shelf queen with the good looks.
Get a 52.1mm or 54mm UCL lens for it. Really good. usd6.25 only. Deep dish big SMO reflector, big AR lens....really good effect.
Thanks for reminding me of the UCL lenses. Ordered one for my F15 right away.
99% transmittance... wow!
Here is one for $33.48.
Do not all bid at once the first person that says "I want it" in this thread should bid for it.
2100 Can you please post a link?
Don't know if the UCL wil not rattle, is only 1.90 mm thick, the standard lens is 4 mm thick
Take two, then nothing will rattle
Or both will
Opps....yeah must consider that. Does the O-ring sit in the same position as the Sky Ray 3xT6 or similar torch? So that you need to put pressure onto the O-ring for waterproofness. Can just unscrew the bezel a bit and shake it.
thommy:Don't know if the UCL wil not rattle, is only 1.90 mm thick, the standard lens is 4 mm thick
Don't have yet the Sky Ray 3xT6 (on its way...)
The SZOBM 3xT6 and the TR1200 are different, this are drop-in and the reflector is screwed into the bezel.
With the X9, the O-ring is just in place when the bezel is screwed tight (It's a kind like the UF 980L, but the X9 O-ring is not so thick)
Here are the tailcap readings:
Battery: eX-cell 3100
Voltage loaded: 4.16 V
High: 3.34A, drops after 30 sec to 3.24 and is stable
Mid : 1.39A
Low : 0.28
After 45 min on high:
Voltage cell = 3.52V
High : 2.01A
Mid : 0.79A
Low : 0.16A
Body gets warm, but less than the 980L
grts.....
Thank you Thommy.
Not very enthusiastic over Mid and Low placement.
