Tmart Group Buy - GO TO THIS THREAD TO SIGN UP - http://budgetlightforum.com/node/29665
I have a Grey SKU 88007127 $ 31.39 . Build Quality is very good.
I’m confidant that my copper pills don’t fit in that one. :~
Well, here's what is going to happen, at least I am pretty sure. Well, that's what it sounds like anyhow. Tmart is going to send me one of each.
Fandyfire SKU: 88013993
No Name SKU: 88007126
Tangsfire SKU: 88008313
That way I can do a comparison review and then decide on one for the group buy.
Yep, it takes longer, but it does make sense. It is good to be able to look each one over, check fit and finish, try them out for Copper pills, test amp draws, modes and then pick the best of the bunch for the GB.
Anyhow, I will keep everyone posted as to when the lights are coming and I will do the comparison review as soon as they do.
PLUS, the losing lights will become giveaways.
TMart sure stepped up to make this happen which shows what kind of business they run.
This may just turn into a HUGH group buy with having all the results for buyers to review.
Thanks for your time and work on this “Epic” group buy!!!
Awesome effort from all involved it seems. Thanks OL for making it happen.
Now for a driver, whatever that is, and some other bits probably.
My Grey SKU 88007127 Pill is 30.88mm . The Copper Pill should fit.
Your pills not fitting would be a deal breaker for me, unless we could get a press fit copper slug. But I think it’s a moot point as neither of the lights being sent to OL is grey. I’m still in either color.
Hmm when did you order it?
Copper pill:
Two year old HD2010 pill that I based off the copper pill from:
Grey HD2010 SKU 88007127 2 months old:
Those images are horrible! Must be using a Nikon! :wink:
LOL!
I CK My TMART Acc . Ordered 10-31-2013 . Shipped ?
Watch out, a Canon fanboy! :smiley:
I ordered mine at 11/29/2013, probably from a different batch.
Not sure what they’re sending out these days…
Thanks for putting this together. I have two already, but would probably be in. :slight_smile:
Yes it is a Lottery . Also the lights OL tests may not be the same as what is shipped for the GB .
Very true, but I will endeavor to control that if at all possible.
:smiley: Good luck on that. Your best magic wand will have to have the dust cleaned of it I say in jest.
This is my official entry for winning one of the three lights being sent out. Thanks.
OL Thanks for the GB + Good Luck. The problem is Tmart may not have 100% Control over Build Quality + Performance, or will they be CK + Testing every Light?
I have the gray SKU: 88007127 on 12/21/13 from the US warehouse and it’s the larger pill.
The threads looked the same to me, what do you think??
The thread pitch? Yeah I think they’re very similar.
Are these a standard Metric size?
I looked at charts and it did not make sense to me.
No. Manufacturers make there own size threads up for I assume to match whatever material they have.
