Tmart Group Buy - GO TO THIS THREAD TO SIGN UP - http://budgetlightforum.com/node/29665
Watch out, a Canon fanboy! :smiley:
I ordered mine at 11/29/2013, probably from a different batch.
Not sure what they’re sending out these days…
Thanks for putting this together. I have two already, but would probably be in. :slight_smile:
Yes it is a Lottery . Also the lights OL tests may not be the same as what is shipped for the GB .
Very true, but I will endeavor to control that if at all possible.
:smiley: Good luck on that. Your best magic wand will have to have the dust cleaned of it I say in jest.
This is my official entry for winning one of the three lights being sent out. Thanks.
OL Thanks for the GB + Good Luck. The problem is Tmart may not have 100% Control over Build Quality + Performance, or will they be CK + Testing every Light?
I have the gray SKU: 88007127 on 12/21/13 from the US warehouse and it’s the larger pill.
The threads looked the same to me, what do you think??
The thread pitch? Yeah I think they’re very similar.
Are these a standard Metric size?
I looked at charts and it did not make sense to me.
No. Manufacturers make there own size threads up for I assume to match whatever material they have.
I am in for one. Thank you.
Well, samples are definitely on the way, but it will be the "normal" shipping, so this will all come to a halt for a couple weeks or more, till they come in. At least I can compare build quality and do measurements. It's a base to start with and if all the lights can come from one run, then they should be a little more consistent.
They may be 0.9mm but I couldn’t get a precise measurement.
If there’s enough interest, a second HD2010 copper pill run may be viable. Thanks OL for your efforts.
I think this is by far the best way of figuring out which light will be the best to buy.
Other than taking a little time all questions will be answered once they arrive.
Thanks for all you time and effort in trying to make this Group Buy work.
Thanks for arranging this! Will be keeping a watch on the review and likely take one after.
Thanks for your efforts … may be in for one!
Anxiously awaiting the verdict! :slight_smile:
I may finally get an HD2010!
I am also in for 1-2, whatever that one is … :slight_smile:
Pretty sure I’ll be in.
