There was links in the thread to two P60 drop in that will just slip into a P60 host, the links still work. One was the solarforce with 380-450 claimed nm. And the Kaidomain with claimed 365nm. The reports from an owner suggest he kaidomain was better, less polluting other light and it charged flouro paint instantly. The SF one did it too, just not as quickly. It was pointed out that light in the 365 range can also do what the ones in the higher range will do, but not vice versa, so the 365 would seem to be the pick to me. If Im reading it right. And at the price point of a few dollars that is.
Hi all,
I own a couple of P60 (502b w/186500) 1W UV lights from DX. They wont light up a $100 USD bill. Based on this thread, I ordered one from KD. Do you think it will work in a 501 with 2 CR123s?
I could be wrong, but I don't think the new US $100 bills have anything that fluoresces in them. Maybe some small fibers in the paper, but I don't recall.
Yeah, ever since I got a CU6 I've been aiming it at random things, like my shoelaces and watch hands. It's really amusing, and probably bad for my eyes haha.
Speaking of which, I got these glasses for my laser, but they really make UV light pleasant on the eye and you really see fluorescing objects so much better. I have several pair of yellow glasses, for some reason these work better. Haven't really compared side by side though. So caveat emptor.
UPDATE: Another member purchased these glasses and reported that they don't work as well as most yellow glasses. I trust that members judgment in this area better than mine.
I know that texaspyro has better output on one cell. I have this KD drop in and find that mine is very much brighter on 8.4 volts than on a single cell. Even though they came from the same source, knowing Chinese venders I would not be surprised to see different drivers or LEDs.
I do find that the KD 365 nm UV does a much better job on bank notes than my unknown 380 nm drop in.
Just received the KD 365nm P60 and to my surprise, there are two emitters inside the dome.
I thought the two emitter version was the 395nm version. I’ve just tried it out on some money and it fluoresces the Australian 50 dollar note OK where as my other 395nm one doesn’t show one of the symbols. Can anyone confirm that the 365nm also has the two emitters? Everything else is as how it was described in this thread.
Another thing is that I bought a purple Ultrafire WF501b as a host. Well the P60 does not fit in the head as the lens retaining ring kept it from going deep enough. I had to remove the lens to get it to fit, but it does mean I’m going to have to use it without the lens which probably has some pluses.
… plus someone claiming that the actual photon output should be around 450mW worth, though I’m not really sure how that translates into a familiar unit like lumens. I doubt the usual 683 lm/W math applies, but if it did, that would mean about 300 “lumens” of mostly-invisible light.
Regardless, assuming the 3000mW figure is correct for its input power, that’s several times as much as the cheap 12-LED 375nm light I have, and at a better wavelength… with a more focused beam and all the other Chameleon extras.
Here's another photo to give you an idea of the strength. The bill is sitting on a white box which is probably treated with some fluorescent. I'm still collecting applications to have this light reviewed.
Yow, UV beam pics are hard. I just tried a bit with my cheapo UV light. Granted, I also have an inexpensive camera and my only UV “filter” is a pair of yellow party glasses… but still.
Here was the light, unfiltered, on a wall. I took this to show the star-shaped beam pattern (which is only visible to the camera when it’s really close to the wall).
This was a 20 GBP bill, with no UV filter (click to enlarge):
… and the same thing, with the yellow party glasses in front of the lens to block UV light (click to enlarge):
None of these show very well what it actually looks like in person. Things fluoresce a lot better to my eye than they do to the camera.
I have this drop in and didn’t notice that it had two emitters, just checked mine - bought a few months ago - and it has two.
It works very well to charge GITD and also works well on “black light” enhanced posters, must be the ageing hippy side of me. :8)
I’m running mine on 18v 6x3v CR123s in a Solarforce L2P with 2 extension tubes, the CR123s rattle a bit but work well, I tried it with a single 18650 fully charged and it was definitely not as bright.
I have several “no name” UV P60s and a couple of Solarforce UVs and the Kaidomain pushes out less visible light and more UV.
Yep, looks like the real deal to me. Tried it out last night and it definitely shows stuff that my 395nm can’t.
In terms of GITD stuff, my 395nm one that runs off 2xCR2032 cells only manages to make a toy GITD lizard glow for 10 seconds after charging it for 10 seconds. The P60 off a single 18650 manages to make the same lizard glow for over a minute and then some! Might have found a metric for measuring UV power.
