I modded mine myself, that said, I talk with Richard and I bought my Qlite from him, as well as my 7135 chips and Noctigon pads and XM-L2 emitters. He builds the driver up in the same way that I do with the same results. Just like me, he does spring bypasses to cut resistance. We both use Panasonic NCR18650PD or PF cells or the Samsung 20R and both get that 5A at the tail cap. I have a light box that was made for me by a couple of very nice guys here on the forum that I mod some lights for. It’s readings are consistent with the readings others get.
If you get one of Richards XinTD V4 modded lights, this is what you’ll be getting. Straight up. Same as if I modded it for you, or Tom E or Race or anyone else. And Richard does beautiful soldering on his stacked chips!
As a matter of fact, I have one of his lights on order that he informed me today he’d completed. (I do believe they call that putting your money where your mouth is.)
I have yet to see a light maintain output while the cell depletes. I haven’t done a runtime on my XinTD V4, Richard might have…don’t know.
I do know that it’s well built, differently built than the Convoy, and is a different color even than all my other lights, and I keep it front and center alongside some of my other preferred models.
Now, we won’t start talking about my Convoy C8 with Buckets 8 ounce+ copper pill mated into it and running an MT-G2 at 5.55A making 1625 OTF lumens at 30 seconds… nor will I go into any depth talking about how it’s still doing 1539 OTF at 2 minutes…
You can now add me to the Convoy C8 owners list. Received mine today, ordered on 02.09.14, shipped on the 12th and delivered on the 22nd.
Thats really not bad, 10 days for shipping.
For some reason I expected it to be a bigger flashlight even though I knew it only took one 18650 battery. You guys were right though its really well built, nice flashlight… Now what? hmmmmm
Blazer1 wrote:
Today I received my second flashlight, a “Super XINT D” @ 5a from Mountain Electronics and lets just say if you want to be happy with your Convoy C8 don’t compare it to Mountain Electronic’s modified XINT D, …wow it is bright!!
I still like the Convoy for the price but it is as weak as water compared to my new light.
How do I tighten down the pill (I think thats what its called). My light is flickering on and off and when I took the lens off the LED portion is loose and rattles a little. I see the 2 indents on top but I don’t have anything to fit them…It also makes a LOUD whine on the medium setting.
Don’t get me wrong, at this price the Convoy C8 is a great light that I can use under any condition and not worry about damaging it. I plan to order a couple more for friends and family. To compare the Convoy to the “Super Xintd” from Mountain Electronics is not a far comparison. After playing with my “Super Xintd” and picking up the Convoy C8 I am constantly thinking the Convoy C8 is on medium so I keep clicking to get to high,…then I remember,…oh yea that is as bright as it gets. :bigsmile:
I found a post from CRX for Improvised Pill Tool using nails and a rubber band that I’m gonna try.
I did get it tightened up some using some pliers and the whine noise went away for the most part. Back to playing with my new flashlight, its dark here finally.
Starting at the top with 1A, this is a cool white (blue/white) tint and the most power available for higher lumens output.
The 1A de-domed is a tighter beam hot spot for more throw at the sacrifice of fairly substantial lumens loss and a lesser tint quality, it should be near white but could be a bit on the green side
Stepping down in these tints get’s warmer and less lumens as you go down, with the lowest being a near tungsten light yellow/orange in appearance for those that still like the color of the lights from yesteryear in a more powerful and more dependable option.
The 3C is near white, a good choice if you’re straddling the fence.
Perhaps this will be some help. 5000K is near daylight white. A camera flash typically works in the 5700K area.
I have been ordering quite some C8´s but in overall quality, this is by far the best.
Hardly anything to rant, naturally the LED dome has a tiny blemish, as about 95% of cheap XM-L lights seem to have.
Reflector has a very small scratch, hard to notice.
From outside and inside otherwise flawless in function and form. Has been generously lubed. O-rings good an intact.
Draws amps like it should and beam is nothing less than 5/5.
Received mine today after 4 weeks. Quite impress with what we can get for $16. There is a small imperfection from machining on the head but the rest is just outstanding. The reflector and lens are very clean without any blemishes at all. I measured the tailcap using freshly charged to 4.15 (and also new) Sanyo UR18650FM and the result is 2.65A. Was that good?
