How do I tighten down the pill (I think thats what its called). My light is flickering on and off and when I took the lens off the LED portion is loose and rattles a little. I see the 2 indents on top but I don’t have anything to fit them…It also makes a LOUD whine on the medium setting.
Don’t get me wrong, at this price the Convoy C8 is a great light that I can use under any condition and not worry about damaging it. I plan to order a couple more for friends and family. To compare the Convoy to the “Super Xintd” from Mountain Electronics is not a far comparison. After playing with my “Super Xintd” and picking up the Convoy C8 I am constantly thinking the Convoy C8 is on medium so I keep clicking to get to high,…then I remember,…oh yea that is as bright as it gets. :bigsmile:
I found a post from CRX for Improvised Pill Tool using nails and a rubber band that I’m gonna try.
I did get it tightened up some using some pliers and the whine noise went away for the most part. Back to playing with my new flashlight, its dark here finally.
Starting at the top with 1A, this is a cool white (blue/white) tint and the most power available for higher lumens output.
The 1A de-domed is a tighter beam hot spot for more throw at the sacrifice of fairly substantial lumens loss and a lesser tint quality, it should be near white but could be a bit on the green side
Stepping down in these tints get’s warmer and less lumens as you go down, with the lowest being a near tungsten light yellow/orange in appearance for those that still like the color of the lights from yesteryear in a more powerful and more dependable option.
The 3C is near white, a good choice if you’re straddling the fence.
Perhaps this will be some help. 5000K is near daylight white. A camera flash typically works in the 5700K area.
I have been ordering quite some C8´s but in overall quality, this is by far the best.
Hardly anything to rant, naturally the LED dome has a tiny blemish, as about 95% of cheap XM-L lights seem to have.
Reflector has a very small scratch, hard to notice.
From outside and inside otherwise flawless in function and form. Has been generously lubed. O-rings good an intact.
Draws amps like it should and beam is nothing less than 5/5.
Received mine today after 4 weeks. Quite impress with what we can get for $16. There is a small imperfection from machining on the head but the rest is just outstanding. The reflector and lens are very clean without any blemishes at all. I measured the tailcap using freshly charged to 4.15 (and also new) Sanyo UR18650FM and the result is 2.65A. Was that good?
After adding a few chips to mine, I was having trouble with the current measured, 2.8 up to 3.5a. It would not read past 3a. I took the pill out and unscrewed the driver to test. 3.48a. Screwed the driver in 3.48~a. Put the pill back in the head 3~a.
I had to clean my threads for it to work properly, the pill threads. I also removed some of the anodizing from the lip,where the head screws on on the inside of the tube. I have no problems with current now.
It is very inexpensive. It does make the driver thicker and creates some heat but in this particular light there’s lots of room. You must add the chips on the bottom of the driver though which can be tricky since there’s little room. I Desolder the chips that are there, stack them, then put the stacked chips back.
While stacking chips are good for better performance you should also change the LED star into direct copper MCPCB, something like the Sinkpad or Noctigon, otherwise the increased light output will sag very quickly and it may even damage your LED in a long run, depends on the current draw anyway.
