You wonder how far a BLUE SUN could throw with a large/deep enough reflector!
Who else other than a flashlight addict would know the approximate surface temperature of the sun (5800K), same as the color of a “daylight” bulb (5000K - 6500K)
If you didn’t know that, you know it now, and won’t forget it.
When you have destroyed two Smart-phones trying to attach a 3 inch reflector for better throw! HB
Post pics when it’s finished
When your family is inside the restaurant eating and you’re outside because there is a huge field to test the throw of the three lights that came in the mail today.
The sun. Definitely needs a reflector, but more importantly, dedomed.
:8) Thought my hot rod Cu C8 light could put light on the point where the guy was welding on our truck this morning.
Need to bump power levels.
Wonder why semi-colon 8 right parenthesis is supposed to make an embarassed smiley but it comes out the sunglasses wearing cool guy instead? Hmmmm….
:8)
When you keep reading this thread and you do mental check boxes on what else you have missed out in this journey…
...When you begin to see PWM in natural sunlight?
when you search for 20mm cooler fan on ebay because you figured a way how to put it in C8 with 3.8A modded qlite … J) just waterproof will be issue :Sp
When your last (one month old) 400K lux light does not cut it anymore! Time for a new one! HB
… when you own a torch whose lumen output is a bigger number than its color temperature.
Or, in a few more years… when your light has more kilo-candelas than Kelvin.
When you have been banned from “The Other Place”. Like a right of passage. Customize a light, get banned from CPF or have one of your posts deleted or thread closed. All some the steps toward adiction. (When I got banned there, I received invites for here. Thanks guys.)
depends on what kind of reward 8)
- You have an addiction when you need more cases for your lights after filling up 5 of them…
When you ask another member where he got those cases
When you have so many lights,that you can’t remember how the UI is supposed to work,or how to power it up. HB
I CAN’T STAND THE TRUTH.
When your personal collection has a larger inventory than even some quite large stores!
When you have more batteries than The Battery Warehouse.
the 4 bigger ones came from Costco and HomeHardware, and the smaller one to the left is the case that came with the Olight SR90, ( i use it for batteries & Chargers atm. )
When your next camping trip is planned around when the SUN ISN’T SHINING!…
