Review of USB battery box 6x18650 Qidian
The current is probably to low.
A problem I have is with one of the Blue LED.
After weeks of usage, the right most Blue led which indicate 5V eventually failed.
Steps taken :-
  1. reflowed the led
  2. replaced with good one.
It also have weeks to days of usage, then start to flicker, slowly dying LED.
Could you test your unit or how can I do to solve it ?
There is no reason for that led to die, except if there is a problem with the resistor:
I.e. is the resistor shorted or the wrong value?
As same as the photo non-shorted 100ohms
Double checked the connection joint also out of clue why it die :weary:
EDIT:
Last attempt, hot-air flow out the resistor & blue led.
Both trace properly wicked clean, fresh Kester solder apply thinly, dab some flux & reflowed back.
Tried for a week, so far so good now, I think the old solder causing problem :slight_smile:
Interesting battery bank, thanks for the review!
what do the buttons do, that are on the electronic board ?
View from top, the left one is Activation button, while the right is On switch & output voltage selection.
hi
if i put Panasonic batteries in this power bank
3400*6 = 20400
how mah should i take out of it
and how do i do the calculation normally
thanks
If you look at my curves, you will find one for 3400mAh batteries.
It shows that one battery with 10 ohm (0.5A) load will last for 250 minutes, that is 2Ah.
With 6 batteries you will get 6 times as much, i.e. 12Ah.
i am sorry i didn’t get that
my question if i charged my power bank in full ( 20400 Mah )
how many mah i get out from the power bank
for me to calculate how many times to charge my iPad or my mobile
sorry but i am newbie
thanks
12Ah is 12000mAh
thanks
i cant understand this
i have Qidian 5 batteries box i put in it my broken Chinese power bank batteries
it written on them 2200
so i put four of this batteries ( 8800 ) in the box
i made calculation i found that i am getting 6050 mah
so its 68.7%
how come i get 58.8% out of this panasonic and they are a lot better
thanks
The total capacity of your 8800mAh is in 4.2V, when it passed the circuitry to boost to USB 5V, there’re sure some losses there.
Hence, you will not get the full 8800mA from it. (a very rough estimation from 8800 in 4.2V is about 5535mA in 5V)
Read those Panasonic Li-Ion datasheet, to get the full capacity, it need to discharge down as much as 2.5V to get the full capacity,
normal powerbank circuitry cut-off at about 3V, so there’re also some minor capacity which cannot be use.
Hope these helps explain your confusion :slight_smile:
Maybe your calculations are not that precise.
There are two loses in mAh when using a battery box, first is due to the voltage difference and it cannot be changed, the other is due to the converter doing the conversion of the voltage. In this box here the conversion efficiency is about 90%.
HKJ,
With this battery box, can the batteries be left in the box as storage? Is there any discharge, if so, what rate?
Thank You!
-d
Check the list of points just after the "Measurement" heading.
Thanks! I was skimming and was looking for the terms like ‘storage’ and ‘drain’ and didn’t see it. So this box looks good to be able to leave the batteries in there for 6-months (emergency batteries?)
-d
6 months will drain about 0.055*24*31*6 -> 245mAh
Even with only one battery in it, it would not be a problem.
Well after about 8 months of light to no use, my power bank has developed a charging problem. USB output still functions normally, but it only charges the internal batteries to 3.85V, then the 80% LED stops flashing. Charging intitally stopped at the 60% mark and I had to reconnect the charging cable several times before it attempted to charge more, but this doesn’t work once the batteries reach 3.85V. It seems to do this regardless of whether there’s 1 or 6 cells loaded. These are new laptop pack pull LG 2200 mAh cells which have only been used in this power bank. The cells are charging / testing without any issue in my Opus, so they don’t seem to be the issue. I may have to poke around to see if there’s an obvious failed SMD resistor or some other component like the poster with the LED failure.
KuoH
Nice thanks!!
Looks like they have a 5X version that can charge thru a micro USB connector as well
http://www.fasttech.com/product/1457403
