As long as the voltage setting is above the LED Vf you should be OK. Look at the LED data sheet and see what voltage would cause too much current for the LEDs and set it there.
LEDs have quite a bit of variance in their V-I curves and the slope is rather steep, so a little change in voltage/temperature can cause a lot of change in current… that is why current limited drivers are used.
Thanks TP, this PSU appears to be strictly a CC driver when wired to the emitter. The voltage adjustment pot does absolutely nothing and has no effect on voltage or amperage. I tested it full range several times to make sure. When its not connected to an emitter it works, but when connected it does nothing. The Amp adjustment pot works well and locks in the set current and holds it there precisely. As expected, the voltage drops as the emitter heats up and the current remains constant.
To summarize setting up this particular driver:
Use the current pot to set emitter output. The voltage pot adjustment does nothing, at least with my applications. I have 15 of these drivers and tested several just to make sure. They are also genuine Meanwell, not some cheap chinese knockoff.
I just mounted one of the emitters to a 20 pound AL heat sink and wired it to the PSU. All I can say is WOW! :bigsmile: These things are bright! :bigsmile: Im running at 3.75A for 7140 lumens, which is 100% rated output and 102 watts being consumed by the psu. Power factor was measured at .97, so these PSU’s are super efficient. A quick glance around the room quickly shows the value of 97 CRI and 3000 K… simply gorgeous light when the entire living room is richly bathed in it.
Cool, sounds real nice. Those warm Bridgelux emitters should do put out gorgeous light. I've only used the 9 volt versions. 2 in series can be driven nicely by an 18 volt laptop power supply. 2 of those can light up a big room nicely. Hard to picture how bright those 30 volt puppies are.
Do you have a bridgelux part number or a link for the ones you picked up? Are yours mounted and in use, or just for play? Fun stuff!! Its amazing how much light these suckers belt out, especially for for the wattage.
I'm guessing I bought them a couple years ago (maybe more). I think I bought them from Digikey, but searching their site revealed nothing that seems to match. The closest I can find is something like this. If I recall correctly (probably not), they are only like 80cri (not 97 like yours).
I have two mounted in parking lights enclosures that I use as axillary headlights in one of my cars. I don't use them in traffic. Used old heat sinks extracted from old computer supplies to mount them on. I used simple linear regulators that have 3 Vdo to reduce the amount of voltage they have to burn up. Still get pretty hot though. Actually need more heat sinking than the emitters.
I only played with them in the house, but haven't yet decided how I want to implement them. I kind of like the idea of using wall sconces to keep the heat away from the wall. Light aimed up to the ceiling for indirect lighting.
I just keep putting flashlight projects ahead of home lighting.
Ive considered an LED DRL conversion but have been afraid to melt the plastic housings during a hot day. If I was cognizant of them (as you are) I’d put them on a switch and use them only while moving… but Im sure Id eventually forget and suffer an expensive plastic melt-down. I have several heat sinks to chose from, but they would all eventually need air flow while stationary.
The indirect lighting approach with the bridgelux seems to be the best one so far. I have the test bed on a table with the emitter pointed up at the ceiling and it lights the entire room in bright light with smooth transitions. I have 12 foot ceilings in the garage, so I might try the emitters with ledil flood reflectors to see if that cuts the glare and makes them more useful.
Ledil makes several asymmetrical reflectors that would be excellent for wall sonace mounts.
I dialed the PSU back to 2.80A to the emitter for 5350 lumens (75% rated power). Recording an hour on my kill-o-watt meter yielded 0.07 kWh. Multiplying that by the kWh charge on my electric bill yields a cost of 0.00506 per hour to run. So an 8 hour run would cost 4 cents, or about $14.78/year @8 hrs per night.
In case anyone is still interested… while running 2 emitters wired in parallel with the Meanwell cranked up to 100% netted the following results:
117W to power the PSU
4.33A into both emitters
1 hour run recorded 0.11 kWh
2 hour run recorded 0.22 kWh.
.11 x $0.072355 per kWh = $0.00795905… so about 0.06 cents per 8 hours x 365 = $23.24/year
A very substantial 20 pound aluminum passive heat sink stabilized at 104 degrees F after 3 hours of continuous operation and vF was measured:
Left emitter = 22.72V Right emitter = 22.69V
A .03V vF variance is very impressive for a parallel setup of this type. I havent had a chance to test the remaining emitters to see if I can vF match a few more pairs, but I doubt there will be any problems.
To my eyes, 2 emitters produces A LOT more light at 4.33A (2.17A per emitter) than a single emitter at 3.75A (emitter max rating). I might break out the lux meter later and record a few ceiling bounce tests to measure the differences. Ultra high CRI warm is the only way to go for wide area lighting and I couldnt have been more impressed. :bigsmile:
My 200 watt metal halide outdoor fixture took a dump last year. When I turn it on, the bulb flashes for a fraction of a second and the transformer only hums. It might be time to try an LED conversion. Now if I can just find a cheap 80-120mm 120 VAC fan.
I probably wont chance it, but I wonder how one of these arrays would take to dedoming and if it would all come off if soaked in gas, naptha, acetone, xylene or MEK? Its hard to tell exactly but all the phosphor appears to be contained within the dome material and not coated over each LED. It would be an expensive mistake if it wasnt successful but it would be cool to have a high powered blue/purple flood light. Any thoughts?
Has anyone tried to dedome a bridgelux brand array yet?
Ive been running one of these emitters @100 watts while mounted to a fan cooled CPU heat sink for several months and with no signs of deterioration. These emitters are designed for commercial applications and should run for several years. Now that the emitter is broken in, Im observing a 100% power factor efficiency while measured through my kill-o-watt meter. The marriage of the high quality Meanwell cc driver + the bridgelux RS emitter are an impressive combo of efficiency and true 97 CRI lighting.
My light meter is at the airport and I’ll try to remember to grab it the next time I swing by. When the bridgelux is powered on, a btu shocker on turbo added to the ceiling bounce is hardly noticeable, but it does detract from the gorgeous 97 CRI.
What an excellent photography light source this could make! Equivalent to what, 400watts in tungsten but with a better tint and higher CRI? Awesome! Could it be run with a potentiometer to dial down total output as desired? Or even a Leviton wall switch with rotary control?
Probably over my head, but interesting as all get out!
You truly have to witness the light quality to appreciate it. I dont know that I could put into words in how blow away I am every time I turn it on. The drivers are large chunky metal boxes designed for sustained commercial applications in wet locations. Ive researched this line of meanwell drivers and couldnt find a mod thread where anyone ever attempted to remove the internal pot and wire an external one in its place. I removed the metal covers and the entire driver cavity is encapsulated in a heavy potting compound similar to dried latex silicon. I could probably take an exacto blade to it and carve a nice neat channel to expose the pot and then go from there. Access would be on the top of the PCB so I couldnt desolder it from the under side. Id have to attempt a removal from the top side, which might or might not be an easy proposition. If I destroyed the pot during the removal process, I wouldnt be able to measure it with a dmm to find its rating. Its just one of those things where I have come to appreciate the comforts of high levels of quality light without shadows, and while bathing everything in brilliant light. I can just see everything a whole lot better and with greater clairty. So Im not sure that Id turn the light down even if I had that as a remote feature. Also, the driver can deliver more power than is recommended (which is 100W max sustained at the emitter) so a pot mod would have to have a corresponding set limit… not sure how to pull that one off without resistors inline. Maybe there is a pot with adjustable limits.
These type of drivers cant be dimmed by a dimmer switch. Wouldnt that be nice if they could?
My only thought for dimming is taking portrait pictures, people can be sensitive to bright light and squint and then get attitudal which doesn’t make for the best portraits. I could always diffuse it, bounce it, whatever.
That sounds like such an excellent set-up, with it being sealed it’d work great for outdoor shoots without worry. Did you say how many lumens you think it’s making? 7000-9000?
I have been thinking of using a commercial 2’x4’ fluorescent bay with daylight white tubes, special tubes designed for the workplace. But I’m just about positive they wouldn’t work well for photography. This set up of yours sounds ideal, and so perfect for product shots as to be droolworthy. :heart_eyes:
Im running at 3.75A which produces 7140 lumens (according to the datasheet), which is 100% rated output. I measured 102 watts being consumed by the driver. Now that the emitter is broken in, Im observing a 100% power factor efficiency while measured through my kill-o-watt meter. Im running mine without any type of reflector on a night stand mounted to a high performance CPU heat sink and fan. Its pointed up at the ceiling and bounces the light through the room. Ive been thinking about concealing the rig in a small wooden box with cooling ports for the fan and adding a ledil flood reflector with lens designed for this emitter. The fan would cool the heat sink first and then the passing air would be channeled over the driver before it exits the box.
The driver is adjustable by pulling out a plug on the front of the driver and inserting a screwdriver to twist a pot. The pot feels high quality and tight, but I wouldnt want to be tweaking it all the time since they probably werent designed to be used as dimmers.
Awesome project, somewere around here (or maybe in storage) I have a vero18 I need to come up with a driver for but I really don’t want to use one of those cheap chineese/eBay ones.
You’re going to have a lot of fun with your emitter after you find a driver and heat sinking solution. My emitters are $75 a piece, so I avoided the cheap drivers because they are often unreliable, dont provide a consistent constant current, especially as they age, warm up or power cycle. They can also provide dirty power, spikes, ripple and be rather inefficient. Although it has other uses, the Meanwell driver I am using was designed specifically as a commercial duty CC LED driver. My kill-o-watt meter is now showing a 100% efficiency conversion on the driver as well. :bigsmile:
Just be aware that there are many fake Meanwell PSU’s on ebay, so chose wisely.
Very interesting! $75 is a lot of money for a 100 watts LED! Is this the price you paid or the retail price?
You should do a comparison with the 100W emitters that can be bought on ebay. I’m sure people would then realize how much better the high CRI LEDs are…
