Worthwhile/Possible/Practical to mod a Fenix L1?
3 posts / 0 new
IamMatt
Last seen: 1 year 11 months ago
I have a couple of Fenix L1's from back in the day when they were the cat's meow, but they seem pretty outdated now (dim).  Wondering if it is possible to EASILY put a brighter emitter and or better driver in them?  Maybe a 3-mode?  I have not done any modding before, but I did take an electronics class in 9th grade (of course, Edison had just invented the light bulb so it was a while ago!) and I am sure I have a soldering iron in the garage.
 If anyone has any experience with these lights, your input is appreciated.  Otherwise I will just let the kids use them for camp or I will keep them as good reliable backups.
Thanks.
Why do I carry a flashlight?  Because half of every day is dark.
FlexakaMal
Last seen: 11 years 2 weeks ago
Remove the old emitter/star ? a few replacements here http://www.dealextreme.com/products.dx/category.917~page.5
If its mounted on a star you just unsolder it pry it out and replace.Put some thermal paste on the back before of course Smile
Welcome to BLF
Don
Don's picture
Last seen: 12 months 1 day ago
Welcome here. Enjoy your stay.
AFAIR all you need is a soldering iron and the LED you want on a 20mm star. Unsolder the existing LED, toss in a SMALL amount of heatsink compound, solder in the new LED - paying attention to polarity. Simple, quick, a great first mod. Since the reflector is set up for a Luxeon LED you'd be best with an SSC LED since they radiate light the same way as Luxeon ones - Cree LEDs don't go all that well with Luxeon reflectors. On a 1W Nuwai device I got 3x the light for twice as long with a simple emitter swap.
This one should be a straight swap
http://www.dealextreme.com/details.dx/sku.1445
This assuming the LED is mounted on a standard 20mm star and it is an original L1 using a Luxeon emitter. I don't own one so can't say for sure. If it says 1W on the body tube, it has a Luxeon LED in it - if it has CE in its name then it uses a Cree LED and this LED is the one you want to swap in.
http://www.dealextreme.com/details.dx/sku.15943
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
