I haven't used it, but I can tell you that XM-L doesn't produce 1200L at 3A or at higher. That's how it is with some flashlights, are rated higher than they really are.
Skip anything that takes p60? LOL, that wipes out about 90% of the XM-L market. I have about 9 of them and have never had a heat issue as long as you use them sensibly. And I LOVE my SkyRay with an XM-L in it, one of the nicest lights to hold on the market, IMO.
XM-L P60 style are the hottest commodity on the budget light markets right now. I would never tell a newbie to skip them....
Easiest way to describe it is that a P60 is a kind of cartridge that includes the reflector, emitter and controlling circuit board all together as a single module.
Many lights take these modules and so are described as P60 hosts.
Naturally you can buy them as a complete flashlight (i.e. both P60 drop-in and the host).
Hope that helps.
The drawback of P60 drop-ins is that the drop-in design is not ideal for conducting the heat away from the emitter to the body of the light. So folks often wrap aluminum foil around the drop-in or strips cut from a drinks can to improve the contact (i.e. heatsinking) I'll try to find a link to a thread on how to do this and post it here later.
Ah! Thanks VFMaddict. That clears things up. So lights like the one I listed above (http://www.dealextreme.com/p/ultrafire-a9-t60-cree-xm-l-t6-5-mode-1200-lumen-white-led-flashlight-with-strap-black-1-x-18650-90602?r=4303328) aren't P60, right?
Quite correct, Getemer, that is not a P60 host. Its probably a good light from the specs but with no reviews I cannot guarantee that. Personally in that class (i.e. lights with a 44-to-46mm head) I think that in the absence of a review I'd be inclined to go instead for this light. As JohnnyMac says most folks around here have one of these in either the Smooth reflector that he linked to or the OP (orange peel) reflector that I just linked to.
I have over 40 Trustfire flames 18650s from DX I have only had 3 that were bad out of 40 and it was the protection circuit only that needed to be removed they all push over 3 amps all 40 of them the unprotected ones push 4.5 amps. I don't know how long ago you got the bad ones but they are safe to order now.
I have the Hobbyking Imax 6 charger to it is awesome love it but it is overkill if you are just starting out.
I have the TR-001 from DX almost a year old I still use it if i am in a rush I don't leave it unattended and I check the batteries with a DMM every time because I don't trust it but it works fine for 8 bucks it's a great deal and a good way to get started into Lions there is a thread on this charger and a lot of people on here use it as well as the Trustfire batteries a very cheap, successful and well tested combination.
I really don't think its good advice to tell someone to avoid P-60 hosts that is 90 percent of the lights people on this forum use day in and day out.
Seriously dude you melted two P-60 hosts I will assume they were direct drive and the Hi Max batteries delivering over 4 amps dedomed the LEDS that is the only way that could happen.
I have dozens of P-60 light they are the majority of my collection most of them are XML and I run them on high until they are to hot to touch not a single dedomed LED. I like the P-60s so much I started making my own p-60 drop in regulated at 2.8-3.5 amps so they won't dedome the LED no longer how long you leave them on.
I really think if there was a problem with P-60s dedoming you would see it here on this forum people love to complain far more than they like to compliment products especially cheap stuff.
You apparently got a couple bad products you did not say were you got them but this sounds like a CPF post.
I would not recommend avoiding P-60 hosts in fact I would recommend starting out with one same goes for the Trusfire flames and the TR-001 charger. I don't want to contradict you for the sake of it but it just seams like you are giving this guy some bad advice. He can go over to CPF and get really bad advice if he wants but I stand behind my advice on the products I trust and use everyday.
You poor, poor normal person, You may not know it but your life is about to change.
I wont tell you what to get as i feel others here are more qualified to do so, No ill give you some tips on how to survive.
1. Start slow, You dont need to buy everything you see as your perception of that item will change as you learn and hang around here.
2. Buy the basics and in the minimum amounts needed. You will have plenty of time to spend cash like a redneck at a "Buck a Pitcher" night.
3. Keep an open mind and learn patience. You can buy good flashlights from within the USA, But it will cost you usually 2x-4x as much as the same item from China.
4. China, The companies you hear about here may have bad reps on the net and there are reasons for that. One is the buyer didnt do his homework. Another is he is very impatient as shipping from China is done by a guy named Chang and he swims the lights strapped to his back into the California ports.
5. Numbers mean nothing, Well ratings that is. Like lumens are ALWAYS exaggerated and battery capacities are never as good as stated. If the numbers are real you can bet you will be paying for that honesty.
6. Safety, Read about Lithium-Ion battery safety and how to not loose a finger or burn your house down.
7. Small cheap lights, batteries, chargers, accessories are all inexpensive from China, But when you make 10 orders in a month its no longer cheap.
8. There are other online flashlight web forums, Most look down on people like us who prefer a good $25 retina burner over a $150 brand name light that is only as good as you value it to be.
9. Asking for a light recommendation thread can last a month if you dont buy something and tell them to stop already, They cant help it as there is possibly a a few million lights made in China. A few in the USA too!
10. Really, two lights are enough and you can stop right there. But you wont.
Now that is some really good advice can't go wrong only thing that could make it better is if you didn't have to wait 3 weeks but there is no way around that.
Okay, okay. I'm pretty much narrowed down on the fact that I want the KD C8. But I have two questions about it:
1. Is the orange peel or smooth reflector better?
2. Do I get the XTAR charger/battery deal for $22, or do I get the trustfire charger/flames?
Second, I'm thinking about getting the Sipik sk68 as a small pocketable light. But I'm wondering if there's anything that is better within that size/price range?
