Kaidomain copper mounted led's
Yes, if it's a board with a dielectric layer under the center pad it will measure open circuit. On a direct copper one it'll read 0 ohms.
FastTech sells these too and some lights ship with them. Awhile ago, I bought a couple just to see. You can grind/sand off the layer and get a cheap SinkPAD style, but then you have to fill that hole back in with solder. I've had troubles reflowing this setup -- can't get the LED to sit down even. Either too much solder or too little - dunno, I found it very hard to get right - don't think I ever did. I never compared head-to-head against alum and SinkPAD's, but the most common opinion is it's somewhere in the middle.
SinkPAD (SinkPAD.com) rates their aluminum direct path XML star for thermal conductivity of 135.0 W/m.K, while the copper direct path XML is rated at 385.0 W/m.K. Not sure what this means in "real world" use for us...
I figured they were fake, but I think these might be direct to copper.
A dielectric layer on top of copper or a dielectric layer on top of aluminum, I think it's probably a waste of good copper. You could put a LED and a dielectric layer on pure diamond and it still wouldn't help.
I’ll tell you tomorrow as I bought 1 or 2 of those as well. Wasn’t planning to use them just yet but I’ll check out the boards in the meantime.
These types of stars are why I hate when people suggest that manufacturers put their LED's on copper stars. That's worthless unless it's a direct bonded copper star, and that really needs to be said when these suggestions are made. Direct bonded copper or don't bother.
Has anyone dissected an aluminum Sinkpad? Is there a copper trace just without the dielectric?
SinkPAD's site (http://www.sinkpad.com/what-is-sinkpad.php) says the average star is 1-4 W/m.K, and the aluminum SinkPAD is 135 W/m.K, then copper SinkPAD is 385 W/m.K, so the major improvement is removal of the dielectric layer.
In their presentation (http://www.sinkpad.com/sinkpad-presentation.php) interesting in that they identify a "thermally conductive" dielectric. They call it MCPCB Type 2. So it appears there is difference in the stock aluminum stars out there, and even if they have a dielectric layer, it could be a "good" one or "bad" one.
Everything I see on their site is saying the aluminum SinkPAD is the same exact design as the copper one, just different base metal used.
Since comfy frequently brings up how copper pills don't work any better than aluminum pills, I wonder if the same would be true with direct bonded mcpcb's. I'm betting testing would come up with the same results for both aluminum and copper direct bonded mcpcb's, but I'm rooting for copper.
The aluminum MTG2 stars from Cutter have a layer of pure evil where the dielectric would usually be. It eats drill bits like you wouldn't believe.
Using copper on a PCB definitely shows output improvement, mostly because the heat density is much higher compared to a pill.
Match’s tests:
But is that improvement from the copper or from the elimination of the dielectric layer... that the improvement exists isn't the question.
Whoops, that’s true, sorry about that.
I vaguely remember a discussion that concluded that copper PCB’s with a dielectric layer was similar to an aluminium PCB rather than a SinkPad/Noctigon.
Ok where is the lumen graph for copper sinkpad and alum sinkpad ?
No one has done that, aluminium Sinkpads are not widely spread so there is no output graph of it
I have 10 sinkpads that I got as free samples, some aluminum and some copper. Does anyone want a copper XM-L and an aluminum XM-L bare sinkpad for some testing? Shoot me a PM, and I’ll try and hook you up.
A machinist told me that the alum might be better . We need to find out.
I see a little project coming up: a kind BLF-er (Slim Pickens) has just this week offered me some aluminium Sinkpads for the Luxeon TX (that I do not posess as yet, by the way). and I would not mind finding out what the aluminium ones do compared to copper, so yes, I would like them, but I do have a spare 20mm copper Sinkpad, so unless it is not going to be used anyway (I will never say no to an extra Sinkpad :-) ) I am already happy with just the aluminium one. PM sent.
It seems you are right Old-Lumens. I removed the sst-90, hit the board with a dremel and tested it with the DMM. All results point to direct copper.
Test the board as is, the way the emitter will see it. If you have continuity then you should also have a direct thermal path. And that board is not the one they showed in the link.
