But there is no dropin with a on-while-pushing-only-mode? Or is this a standard feature?
If this is standard I will opt for the 5 mode and take the complete 504B from DX?
The battery case looks very good.
What about a good pocket the flashlight fits perfectly in?
Has the 504B a forward clickie? It isn’t mentioned in the detials.
That would mean that I could turn on the light by pushing without click. I sometimes accompany a friend who is hunter and it would be definitely disturbing to have to click through all modes when light is required only very short.
I have already seachered for a pocket. But who can advise if the pocket will fit adequately to the flashlight?
I thought that there would be a favourite you guys are using.
Is the 504B is a reverse clickie?
Reverse clickie is a no-go for me as you have to click through all modes until light is finally off.
The L2T body looks really nice to me, thanks for the advise.
So I will still have to order the parts seperately.
Where is a XM-L 6T dropiin available at the lowest price and best quality, at DX or somewhere else?
E1320, can you recommend a good pocket for the flashlight, now for the L2T body?
The holster(pocket) I use I bought local the DX ones I can't vouch for. I don't have any Solarforce lights either so I can't vouch for those either but people on here love them. The 504Bs are reverse clickies most budget lights are reverse clicky except for Solarforce.
This is the drop in to get 3 mode low medium and high no strobes or flashies to go with the solarforce.
No clue on the holster. That is a fine drop in if you want 5 modes low, medium, high, strobe and sos if you want 3 mode high, medium and low the Manafont one is better. I would order from Manafont if you are going to get the Solarforce light.
For which reason would you order from Manafont?
With a front clickie I would even prefer a 5-mode. Strobe would be nice, but isn’t really suffcient.
What is the difference between textured and smooth reflector?
Anybody that can recommend a good fitting holster for the Solarforce L2T body?
How long will the driver remember the previos mode. I think this is temporally only?
So to switch on the light in the first mode (high), you have to push the button until the click.
What happens now when you only press lightly without clicking (next mode?) and what when clicking again (light off?)?
Is there a difference between dropin with smmoth and textured reflector?
Just to clarify that a reverse clickie is not what I'm looking for:
Momentary is not possible when light is off. You have to switch permanently on first, button has to click. Correct so far?
What happens now when pushing the button lightly so that it won't click? And what when clicking?
A textured reflector should be the better choice for me. But the difference is probably not this big, is it?
reverse clicky multimode lights work like this: light is off, pushing it all the way so it clicks switches the light on (mostly on last used mode, high for example)
slightly pushing it for a short time will change the mode to next one
when the light is on for few seconds on one mode and then turned off, it will turn on in that mode (in some drivers the memory is with the light turned off for some seconds, some don't have memory at all, always start on high)
forward clicky multimode is weird, you have to slightly push it to turn it on momentary and depress the clicky to change mode, you can't change mode while on
OP reflectors are better for bike, smoother beam is better
So is momentary light not possible with a reverse clickie?
Momentary function of a forward clickie is that what I'm looking for.
Changing the mode means to switch the light off (click), then again on (click). Hence there is no memory and you have always to click through the complete modes to have the mode you had before switching off?
Can nobody of you guys answer m question regarding the clickie?
That’s quite important to me and the last issue before placing the order…
I would prefer the forward clickie because of the momentary light. How exactly is the operation of the L2T host with the 5-modes XM-L 6T dropin from DX:
When the light is switch on in the 1st mode. What will happen when switching completely off and on again (2x click)? Will the light run in the 2nd mode then?
Does this mean that you always have to click through the complete 5 modes to start again in the mode you have sitched the light off before?
Or is there at least something like a memory function that is deleted after a certain time so that the light runs in the first mode regardless of the mode the light has been switched off?
So when you are in mode 3 for example and you swith off the light for some certain seconds and then switch on again, it will start in mode 1 again, right?
How many seconds does it take until memory gets deleted normally?
Crazy modes, I hope that the use of this dropin http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-450-lumen-smooth-aluminum-drop-in-module-with-textured-reflector-55026 will be as easy as possible.
As momentary light is very important tome I have to live with this memory feature.But I do hope that the memory sets after short time in the off mode.
One last questions regarding the modes.
Is the momentary light always @ hi mode or could it also be @ 1st mode (which is low for the dropin above I wnat to order)?
If you look at the comments on the drop in that I posted on the DX site the first one I recieved was under driven AK47 1.4 amps but the last 2 I got came with ultrafire direct drive drop ins 3+amps.
Those bike mounts are super heavy duty I bought one and then 2 more they work excellent for off road they don't move at all when tightened and have been holding up very well. Shiningbeam sells the same ones for a lot more money.
