So far I have only single 18650 lights. This will be my first multi cells light. Does this light require special battery? I mean protected or matched unprotected cells? Thanks.
This is parallel config, it is quite forgiving. You can use between 1-4 batteries. It is recommended to have matched set of course, but it is not as crucial (vs serial config).
Protected cells are recommended as previous SRK drivers allow rundown to around 2.3V which is bad for the battery. And that stop is not even caused by the driver, it stops only because the Vf of the XML already reached its lowest. In other words, the known SRK drivers did not have low voltage protection. No reason to suspect this driver will implement it, as they normally only copy each other.
Hehe, nice insight if mAh’s was the only decision criterium
As I understand, the discharge curve of the Sanyo’s is more flat. I consider this as an advantage for the SRK. Am I right?
You’ll get more high-brightness time with the Sanyo’s, but less overall run time. Personally, I always use fresh batteries when using it to show off anyways, so prefer to simply have a higher capacity on the batteries. I keep it on low mode hours at a time, so the more time between battery swaps, the better. It’s all user preference!
As said above if you are showing it off you are prob using full batteries= no diff. On a long usage you arent needing the extra time of absolute of max output probably, you want more run time. Depending on how its driven, it may be 6 hungry LEDs @1.6A (guess), so I guess ask yourself if it has 65min vs 85min of battery, how long are you going to walk, and if longer than 60 min, are going to want to carry and change out 4 batteries in the dark. Remember its unpredictable though because we dont know what the LEDs are driven at, or if it is less efficient, it could be a more significant difference if they are driven better, could be 40 mins or less with the 2600mAh’s.
So tempting even as 6x XML, I’m finding “reasons” to buy more myself…gifts for family and mobile lamps right? But then the reality of “they need batteries, charger and education” creeps in, and I guess I’ll have to keep them all myself…
I think it may happen later (someone check my logic). With 6 emitters, each is likely driven at lower current than typical 3 emitter versions. At lower current Vf is lower, allowing the cells to be discharged lower.
