Hhhmm, I know Richard (RMM) has a great write-up on doing resistor mods somewhere... I probably don't do it the recommended way. What I do:
dab a little flux on the board resistor being mounted
lay the new resistor on it, hold in place with a tweezer (other fine tipped things will do)
get some solder on the tip - not too much, not too little either, and hold on one end till the underlying solder melts and the solder on the iron flows to the resistor - check carefully you got a good bonded connection
then do the same with the other end, still holding the resistor down
inspect the solder bonds closely - with a loop/magnifier (continuity tests probably don't work too well because the typical DMM's see continuity across these low value resistors anyway)
Other way is to dab some solder onto the ends of the board mounted resistor first before laying the other one down, but for me, it makes it awkward to hold the new resistor down in place.
I got a perfect holster for this light! Actually, got a few of these holsters because they fit sooo many lights, like a HD 2010, T08, J12, J18, etc.....
This one: fasttech.com-1330400-niwalker-holster, and for $4, you can't go wrong. I use them for my J18's because it's much better than the one the light comes with. I'm think'n GarryBunk may have been the one who first pointed this holster out for the HD2010.
I hope we get some comments on which battery is best, Keeppower 4500 protected, or the King Kong 26650 4000 mAh ICR26650 Protected, the EnerPower 26650 4500mAh, or another ?
thats a nice holster. so does the tube from the j18 go through that hole on the bottom of the holster?
do you think a 9x xml head would fit that holster as well?
It's not a perfect fit for the J18's, but it works. The end cap will hang a little on making it past the bottom threads, but it gets past them. Also, you have to force the head down a little to get the flap to catch the Velcro. I only use holsters for carrying the lights to protect them - I don't wear them very often, specially ones this big. It's a heavy gauge material though, and it's length protects the HD2010's and T08' pretty much fully, while the Y3 hangs out just a little.
Post #86 has details of the mod. I've gone to 4.2A or so on HD2010's and T08's and with a full de-dome mod, over 200 kcd can be done. For the Y3, it's a bigger reflector and this mod I did is even higher amps. Also, de-doming should double the throw, so 270-285 kcd I would expect from this light mod if de-domed.
I ordered some precision resistors from Fasttech. I think they’re R200s…but they are so small. Like sooooo smallll. Did I order the right thing? I’m not a giant or anything, but the chances of me bring a component that is this size with another component this size is, well, small.
My Yezl Y3 Has arrived, I put in my King Kong 4500 and took it out, too bad I am among houses and street lights though.
I live in the city and can’t tell much about throw, but my impression is that the throw is substantially better than my XIN TD, I look forward to testing this in a more remote area.
Something that I could see, is that it is a nice light and feels like quality, the low and medium are great, and I love that side switch, and the fact that the brightness mode is guaranteed.
I sure wish that smooth tail switch was on my XIN, and the side switch also.
Get out in a better setting and you’ll see just how much further it throws than you can now. My cousin’s ranch is so dark you can see Milky Way configurations. In a setting like that, you’ll appreciate it much, much more. Cities generally suck for throwers.
There was one tiny sliver of darkness between two distant trees where I got the firm impression that I was going to love the throw as vastly superior to my XIN, which is my current thrower.
I’m really glad that you posted the thread on it, and that it was at Wallbuys.
Now I need to spend another $15.00 at Wallbuys this month.
So there’s no apparent difference between type a and type c? Have I missed a detail?
Tom E, could you comment further about the heat sinking? I have my HD2010 running 5-6 amps DD and it gets warm after about two minutes. This and the driver mod-ability are the only things holding me back.
Don't have a type C, but believe it's the same driver. I'm not really too interested in the type C - no 8-12v high amp drivers with e-switch support.
Well The HD2010 has good heat sinking, but the uni-body type design of the Y3 is probably superior, plus lots of heat sinking in the most critical area.
