Tmart Group Buy - GO TO THIS THREAD TO SIGN UP - http://budgetlightforum.com/node/29665
OL Thanks for the GB + Good Luck. The problem is Tmart may not have 100% Control over Build Quality + Performance, or will they be CK + Testing every Light?
I have the gray SKU: 88007127 on 12/21/13 from the US warehouse and it’s the larger pill.
The threads looked the same to me, what do you think??
The thread pitch? Yeah I think they’re very similar.
Are these a standard Metric size?
I looked at charts and it did not make sense to me.
No. Manufacturers make there own size threads up for I assume to match whatever material they have.
I am in for one. Thank you.
Well, samples are definitely on the way, but it will be the "normal" shipping, so this will all come to a halt for a couple weeks or more, till they come in. At least I can compare build quality and do measurements. It's a base to start with and if all the lights can come from one run, then they should be a little more consistent.
They may be 0.9mm but I couldn’t get a precise measurement.
If there’s enough interest, a second HD2010 copper pill run may be viable. Thanks OL for your efforts.
I think this is by far the best way of figuring out which light will be the best to buy.
Other than taking a little time all questions will be answered once they arrive.
Thanks for all you time and effort in trying to make this Group Buy work.
Thanks for arranging this! Will be keeping a watch on the review and likely take one after.
Thanks for your efforts … may be in for one!
Anxiously awaiting the verdict! :slight_smile:
I may finally get an HD2010!
I am also in for 1-2, whatever that one is … :slight_smile:
Pretty sure I’ll be in.
https://budgetlightforum.com/t/-/25337
The thread above is where the comparison review is and we can discuss more there.
Thank you
I’m also in for at least one! Regarding the price I may also buy two. :slight_smile:
Funny, I had been looking for a HD2010 to buy. I’d be in for one.
Tmart Group Buy - GO TO THIS THREAD TO SIGN UP - https://budgetlightforum.com/t/-/25377
OK
