The big diode & inductor (must be used together), & big cap are optional. Depends on how low the low needs to be, and whether it needs to be dead silent or not. There's a range of inductors that will work also, 1.2uH gives a pretty big effect on dropping the low mode reeeeally low, but anything from .58 to 1.2uH can be used. The 1.2 is a good baseline choice that should work for 90% of folks.
Thanks tivo, done.
CC, that is an excellent idea and now in the op.
Awesome!
FET comes from the EBAY link (I already have 10)
Payday I will be ordering 3x FET SKR, 17mm, and more than likely the 15mm as well (need a link to the FET though)
I already have 10x Tiny13’s and control items (the diode, resistors, and cap)
But with that link, I know which ones to order if I need more of Tiny13 control components
I think I might also whip up 2x of the Texas Pyro 20mm Nanjg’s as well (I have 50 of those 3 leg diodes in his design)…might do a giveaway and find guys that have a good record of testing drivers and send them a few to test em out (I can build em but don’t have the setup to properly test and whatnot)
Wicked cool idea on the pre-populated cart…great job!
You want any of those 2502’s with your Tiny10’s? I should have 10 about when the boards arrive.
You talking to me? If so sure…would you like me to build you a TexasPyro 20mm and ship back to you for trade?
and/or can you test the 32*7135 build? I really don’t have any way to do a current test and/or a SRK with enough heatsinking to hold up to that kind of current…plus it seems you have a much better setup (I don’t really have one) to test/review boards or whatever
I have 2 of the V1 no tab SRK boards by Mattaus (will be getting 3x V1.1 asap [probably not this payday as I had to replace a ruptured water heater today ], haven’t put em together (shouldn’t take but an hour or so) but still have 2/3 of 100 7135 strip I got from FT…
This should be a similar cart for the 17DD & 20DD boards: http://www.digikey.com/short/hqzd0
The Vishay 70N02 FETs are here: http://www.ebay.com/itm/271319198579
For those who want one-stop-shopping and/or single parts instead of the batch of 10pcs from ebay, this part from Digikey should be about the same: http://www.digikey.com/product-detail/en/AOD510/785-1481-1-ND/3603497 I have not personally used one so no guarantees, but the 'important' specs look right. TO-252/DPAK, 3.2mOhms, 21nC gate charge, low gate threshold voltage, etc.
I just noticed the ebay listing, there was only 1 sold when I first found them, now it's up to 56. lol.
Wow, what happened to the price on the tiny13?? Last week I ordered 30 @ $0.54 each, and right now the same quantity of the exact same part in the same packaging is $0.99 each?! :O
Something change recently?
$0.54 each or per set of three?
I’ve done ⌀ 10.11 mm for $0.75 (set of 3) and ⌀ 10.39 mm for $0.80 (set of 3). Its still giving the same prices if I go to reorder those. Same prices for other projects too.
“Tiny13” or Tiny12? If not the 12.12 mm Tiny12 then what is the exact size of these $0.99 boards?
Noooo, this: http://www.digikey.com/product-detail/en/ATTINY13A-SSH/ATTINY13A-SSH-ND/1995468
Last week the price break for 25pcs was $0.54ea. I don't remember what the price for a single was, but it was under a dollar.
Oh.
Time to head over to mouser? ” ATTINY13A-SSH”:http://www.mouser.com/ProductDetail/Atmel/ATTINY13A-SSH/?qs=sGAEpiMZZMvqv2n3s2xjsXXO6c5bDp3ygADAHDWmQ4I%3D qty 1:$0.86, 25:$0.546
Daggum, even the SSU is up over a dollar!
http://www.digikey.com/product-detail/en/ATTINY13A-SSU/ATTINY13A-SSU-ND/1914672
$.63 for 10 or more
If you order 3 or more, price drops alot!
Code indicators:
– H or 7: NiPdAu lead finish
– U, N or F: matte tin
– R: tape & reel
So SSH is NiPdAu lead finish on the leads, SSU is matte tin, not sure if that matters
Lead finish differences don’t matter enough for our use.
I only used that one making the lists because at the time, it was the cheapest one Digikey listed. That price bump moves the total cost up to where it's getting close to being cheaper to use a 105C as a parts donor. Sucks.
Absolute rock-bottom pricing would probably be in bulk from somewhere like aliexpress, but you have to take into account the shipping time and possible shady sellers/counterfeit parts. Probably not worth the risk.
Should I delete the carts?
One thing I have to say about OSHPark is that they seem to struggle with solder mask layers. I just received 2 batches of boards (unrelated projects) with incorrect solder masks. I checked the projects on OSHPark and the automated renders look fine. However on my boards they are not! One one board there is mask where there shouldn't be (so now I have to hand scrape it off so I can solder to the copper underneath). On the other board there is no mask where there should be, so I have no guide at all when soldering the components down.
Thankfully I can more or less use both boards as they are not critical. It's just frustrating, especially seen as I've been waiting 3 weeks for the boards.
Oshpark will remake errors. Doesn’t sound like you’d wish to wait another 3 weeks though.
Back side of the 7135 layers were a bit squiffy too, but functional
This is a phenomenal resource.
I’m surprised at the sole emphasis on linear divers though. Are there no open source step-down/buck circuits?
