You want any of those 2502’s with your Tiny10’s? I should have 10 about when the boards arrive.
You talking to me? If so sure…would you like me to build you a TexasPyro 20mm and ship back to you for trade?
and/or can you test the 32*7135 build? I really don’t have any way to do a current test and/or a SRK with enough heatsinking to hold up to that kind of current…plus it seems you have a much better setup (I don’t really have one) to test/review boards or whatever
I have 2 of the V1 no tab SRK boards by Mattaus (will be getting 3x V1.1 asap [probably not this payday as I had to replace a ruptured water heater today ], haven’t put em together (shouldn’t take but an hour or so) but still have 2/3 of 100 7135 strip I got from FT…
This should be a similar cart for the 17DD & 20DD boards: http://www.digikey.com/short/hqzd0
The Vishay 70N02 FETs are here: http://www.ebay.com/itm/271319198579
For those who want one-stop-shopping and/or single parts instead of the batch of 10pcs from ebay, this part from Digikey should be about the same: http://www.digikey.com/product-detail/en/AOD510/785-1481-1-ND/3603497 I have not personally used one so no guarantees, but the 'important' specs look right. TO-252/DPAK, 3.2mOhms, 21nC gate charge, low gate threshold voltage, etc.
I just noticed the ebay listing, there was only 1 sold when I first found them, now it's up to 56. lol.
Wow, what happened to the price on the tiny13?? Last week I ordered 30 @ $0.54 each, and right now the same quantity of the exact same part in the same packaging is $0.99 each?! :O
Something change recently?
$0.54 each or per set of three?
I’ve done ⌀ 10.11 mm for $0.75 (set of 3) and ⌀ 10.39 mm for $0.80 (set of 3). Its still giving the same prices if I go to reorder those. Same prices for other projects too.
“Tiny13” or Tiny12? If not the 12.12 mm Tiny12 then what is the exact size of these $0.99 boards?
Noooo, this: http://www.digikey.com/product-detail/en/ATTINY13A-SSH/ATTINY13A-SSH-ND/1995468
Last week the price break for 25pcs was $0.54ea. I don't remember what the price for a single was, but it was under a dollar.
Oh.
Time to head over to mouser? ” ATTINY13A-SSH”:http://www.mouser.com/ProductDetail/Atmel/ATTINY13A-SSH/?qs=sGAEpiMZZMvqv2n3s2xjsXXO6c5bDp3ygADAHDWmQ4I%3D qty 1:$0.86, 25:$0.546
Daggum, even the SSU is up over a dollar!
http://www.digikey.com/product-detail/en/ATTINY13A-SSU/ATTINY13A-SSU-ND/1914672
$.63 for 10 or more
If you order 3 or more, price drops alot!
Code indicators:
– H or 7: NiPdAu lead finish
– U, N or F: matte tin
– R: tape & reel
So SSH is NiPdAu lead finish on the leads, SSU is matte tin, not sure if that matters
Lead finish differences don’t matter enough for our use.
I only used that one making the lists because at the time, it was the cheapest one Digikey listed. That price bump moves the total cost up to where it's getting close to being cheaper to use a 105C as a parts donor. Sucks.
Absolute rock-bottom pricing would probably be in bulk from somewhere like aliexpress, but you have to take into account the shipping time and possible shady sellers/counterfeit parts. Probably not worth the risk.
Should I delete the carts?
One thing I have to say about OSHPark is that they seem to struggle with solder mask layers. I just received 2 batches of boards (unrelated projects) with incorrect solder masks. I checked the projects on OSHPark and the automated renders look fine. However on my boards they are not! One one board there is mask where there shouldn't be (so now I have to hand scrape it off so I can solder to the copper underneath). On the other board there is no mask where there should be, so I have no guide at all when soldering the components down.
Thankfully I can more or less use both boards as they are not critical. It's just frustrating, especially seen as I've been waiting 3 weeks for the boards.
Oshpark will remake errors. Doesn’t sound like you’d wish to wait another 3 weeks though.
Back side of the 7135 layers were a bit squiffy too, but functional
This is a phenomenal resource.
I’m surprised at the sole emphasis on linear divers though. Are there no open source step-down/buck circuits?
If you know of any working schematics…maybe someone can design the PCB
Plus I think the FET and 7135 ATtiny13 driven has TONS of research already done and is MUCH simpler than buck circuits of any sort of high power output
Alot easier to design and proven to work…
I can only speak for myself but it's basically because they are bloody difficult to get right and take a lot of time to get working. For the most part, linear and DD drivers take all of 5 minutes to get a basic design working. I'm more than happy to open source the basic stuff but the drivers that take hundreds of hours to get right are a different story.
On the other hand I'd be more than happy to contribute to a team designed open source switch mode driver.
It’s not so much an emphasis as hopefully a starting point. A bunch of boards were designed in a short time and it made sense to me to get them all together. Any flashlight related Oshpark projects would fit the bill and I’d love to have boost and buck boards posted as well. Help us find them!
