How long will the driver remember the previos mode. I think this is temporally only?
So to switch on the light in the first mode (high), you have to push the button until the click.
What happens now when you only press lightly without clicking (next mode?) and what when clicking again (light off?)?
Is there a difference between dropin with smmoth and textured reflector?
Just to clarify that a reverse clickie is not what I'm looking for:
Momentary is not possible when light is off. You have to switch permanently on first, button has to click. Correct so far?
What happens now when pushing the button lightly so that it won't click? And what when clicking?
A textured reflector should be the better choice for me. But the difference is probably not this big, is it?
reverse clicky multimode lights work like this: light is off, pushing it all the way so it clicks switches the light on (mostly on last used mode, high for example)
slightly pushing it for a short time will change the mode to next one
when the light is on for few seconds on one mode and then turned off, it will turn on in that mode (in some drivers the memory is with the light turned off for some seconds, some don't have memory at all, always start on high)
forward clicky multimode is weird, you have to slightly push it to turn it on momentary and depress the clicky to change mode, you can't change mode while on
OP reflectors are better for bike, smoother beam is better
So is momentary light not possible with a reverse clickie?
Momentary function of a forward clickie is that what I'm looking for.
Changing the mode means to switch the light off (click), then again on (click). Hence there is no memory and you have always to click through the complete modes to have the mode you had before switching off?
Can nobody of you guys answer m question regarding the clickie?
That’s quite important to me and the last issue before placing the order…
I would prefer the forward clickie because of the momentary light. How exactly is the operation of the L2T host with the 5-modes XM-L 6T dropin from DX:
When the light is switch on in the 1st mode. What will happen when switching completely off and on again (2x click)? Will the light run in the 2nd mode then?
Does this mean that you always have to click through the complete 5 modes to start again in the mode you have sitched the light off before?
Or is there at least something like a memory function that is deleted after a certain time so that the light runs in the first mode regardless of the mode the light has been switched off?
So when you are in mode 3 for example and you swith off the light for some certain seconds and then switch on again, it will start in mode 1 again, right?
How many seconds does it take until memory gets deleted normally?
Crazy modes, I hope that the use of this dropin http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-450-lumen-smooth-aluminum-drop-in-module-with-textured-reflector-55026 will be as easy as possible.
As momentary light is very important tome I have to live with this memory feature.But I do hope that the memory sets after short time in the off mode.
One last questions regarding the modes.
Is the momentary light always @ hi mode or could it also be @ 1st mode (which is low for the dropin above I wnat to order)?
If you look at the comments on the drop in that I posted on the DX site the first one I recieved was under driven AK47 1.4 amps but the last 2 I got came with ultrafire direct drive drop ins 3+amps.
Those bike mounts are super heavy duty I bought one and then 2 more they work excellent for off road they don't move at all when tightened and have been holding up very well. Shiningbeam sells the same ones for a lot more money.
Regarding this under driven thing: Is there a big differnce in the light output between under and direct driven?
I would like to have as much as as possible in hi mode. I still got the med and low mode for extending batterie's life.
Or will there araise a problem with heat havin 3+ amps?
Btw how many amps got the drop-in which comes with the 504B from DX?
I will try the mount that E1320 uses because it looks very solid to me, more than the other one does. E1320 very nice bike. When your flashlights don't move riding this bike appropriately off-road than it will also hold on my bike. Only thing is that the bike is remarkably clean..;)
Tonight a friend of mine showed me his Powerlight HX-G011 which was quite cheap.
Yes, it must have been cheap as the light output is defintely bad and ugly blue to purple.
How much better is the 504B in comparison?
But it was good that I tested this flashlight. The Powerlight has a reverse clickie and I realized that reverse is absolutely okay. The clikie is not as loud as feared and you can handle it very fast.
Overall the handling seems easier and smoother to me as this of a forwrd cklickie.
Lol 118 posts. With all due respect, buy one already!! =P It's not rocket science, and I'm sure you'd be satisfied with just about any of the setups mentioned.
