I have been using this without any hassle.
Question, could you scoop a glob of it, put it in a syringe with say a 14ga blunt tip needle (I use rotary tool and diamond wheel to grind sharp tips flat [I use it to put e-juice in my vapor systems thru small screw holes) and use that to place small bits of solder paste on the pads for reflow?
I used the full syringe tube that I got from amazon to dab globs of this on the pads when I made my 32*7135 SRK and 20mm TexasPyro Nanjg driver
A stencil from OSHStencils would DEFINITELY be a good idea if you plan to make more than one at a time (and they do VERY good work, I got both my stencils for the above, havenāt used them yet, but got the plastic mask and stencils for very cheap!
Here is rosin solder flux
https://www.fasttech.com/products/0/10001213/1101900-high-intensity-soldering-flux-paste
But definitely like that FT solder paste! NICE!
I have been using a toothpick, but stencils would be much faster and more precise for quantity work.
Hi,
first thank you to the thread starter for this nice mod and detailed review, I really like this stuff Now my UF-T20 have arrived and i really like it. Still waiting for drivers and leds, seem there is no luck there for meā¦
Borg, liked very much your work too, and I am for xpe mood too. Still one question in my mind, how its possible u have spend all this in torch and leds and so on and still are missing a lux meter? I strongly advise you to get one, it will help you and us a lot.
With my bad luck with mail I have, got a lux meter and still waiting for led and drivers to arrive lol.
ah one more thing I am measuring stock UF-T20 and is giving me around ~ 22Klux, but my batteries are cheap TrustFire. Look that reading ok ?
22klux sounds plausable, that is what you can expect of a xml in a good zoomie.
(thanks for the thanks, I would have never thought that this thread would attract new posts even after a year :-) )
Well I believe this thread will go strong for a lot more than one year
Personally i like throwers, and really like pocketabile ones with just 1x18650. My dream one will be one that is small like an M2 for excample or even a little bit smaller and throw 100Klux and up (pretty much impossible by today standards I know)
This T20 is in the upper limit of the size to my tastes, so I will try to experiment a little bit with it with the hope to up the lux numbers as much as i can.
You have wrong tint for XP-E2... Try 1A or 2B tint... To me it seems like you are in 180KCD range with this mode. Get yourself light meter and open a thread with your version of Vavien collar I will buy it :)
Stock Trustfires X7(sst-50& 80) are not throwing more than 50kcd, and I did not to try to mode one with XP-G2 because it seems that it has not right shape of reflector for that little led.So I think you are in 120 kcd range with your mode(and it would probably throw 200 or more kcd if you dedome it? Why not? 2B is my favorite tint for dedoming).
Ervin Anastasi,
no lux meter until my current aspheric project is done
luminarium iaculator,
in the beamshots i locked the white balance to ādaylightā . This makes the image to look more warmer. In reality, the spot is much more cooler.
i choose XP-E2 R4 (6100-6500K) tint because it was the only option from intl-outdoor.com store. I assume that 1A and 2B tint are cooler ?
Anyway, after installing a recycling light collar the tint becomes even more warmer than after dedoming.
About the Trustfire X7, if you check this thread by Andi , last page, post nr. 110, you will see that a hard driven and well focused dedomed xpg2 in the X7 will do 400-450 Klux.
About the recycling light collar, i am sure a lot of people would buy a collar custom made to fit the Uniquefire UF-T20, but also i do not think that wavien would be very happy about it, since they patented this technology. So i do not think this will going to happen
For now, i will not dedome the XP G2 2B in the Trustfire X7.
I bought the X7 to mod it into a aspheric thrower with a hard driven XP-E2 + 75mm lens . The XPG2 is installed now just to see how it shines with it, until my new lens arrives.
I want to report about the kaidomain 80mm aspheric lens link
This lens is not good for maximal throw, it has a bright spill and it can not focus all the light in the spot.
This is how the recycling light collar custom made for the Trustfire X7 looks :
Looking good that collar... Why would you not sell it to people? This is budget forum so you could make something with acceptable price to us and earn some $? I am first on waiting list...
Do you use welding mask when centering this collar? Or maybe moonlight mode only? I would have to use some eye protection for this because I mostly have single mode drivers.
Yes indeed XP-E2 R4 from IO are cool white with 1C tint(a bit greenish tint)...
Night picture taking is hard and with phone camera even harder so I should not judge the picture.
Illumination supply carries XP-E2 with 1D tint if you want to try something similar...
I don't think Andi gave correct data... It would be lucky if it throws 300 kcd with driven XP-G2.
"I bought the X7 to mod it into a aspheric thrower with a hard driven XP-E2 + 75mm lens"
Tried that in Xsearcher aspheric and if you find good aspheric it will be true laser like beam( I don't like it since it is smaller and I got even lower results than with hand selected XP-G2 2B (the brightest out of 20)
My advice is:
- No point of driving XP-E2 more than 2.8 A (no results and heat will be enormous if you will tune it up with more chips)
- Stick to newest XP-G2 S2 (brightest XP-G2) and order at least five pieces and select the brightest of them(you will surprise how much lux you can gain with right selection of emitters)
This is mine 450KCD(with lower performing brothers I had from 380+) Xsearcher with hand selected XP-G2 R5 2B driven at 3,6A heavy fog( I don't want to tune up further because it is single cell light)
I will try to made XP-G2 S2 1A (which should outperform this setup up to 10% or more if I find brightest among lot of them because 2B is in its upper performing class. If you don't understand what I talking about read here about led bins and performance deviation http://flashlightwiki.com/Cree )...
In fact I have 6 pcs of them I am just to lazy to start...
Looking forward for your build but I think it will be extreme hard to find good aspherics for X7. Good luck.
Tint graph:
Yes, i centered the collar using moonlight mode.
Recycling light technology is patented by Wavien and start selling the custom collars here would probably be like calling for trouble.
It would be nice if somebody that understands exactly how the law works in this case would step in and explain if there is a way of selling the aluminium collar clone without getting in trouble.
NĆ¢h, itās unreasonable to patent properties of light (i.e. laws of physics), so f*k Wavien, and f*k LedLenser while youāre at it.
The nerve of some peopleā¦ I mean reallyā¦
Inventions are usually discoveries anyway, so there.
I was looking for a picture here of the main tube, unmodded, because i just modded mine, taking care of the focussing business.
But i donāt have the ābeforeā picā¦
So, I have a UF-838 that I was going to put a de-domed XP-G2 in with a 3.04A Qlite / NLITE driver. But it has a hollow pill and I havenāt had the motivation to build a heat sink, and it has a rather long focal distance so itād probably lose a lot more lumens than necessary when focused. My estimate is that itād max out at about 60 kcd, based on holding the optics in front of another de-domed XP-G2 I have and measuring it.
Iām thinking it might be a better idea to just buy a UF-T20 to mod instead, and keep the UF-838 as a flooder. In wide mode, its lens is only like 1mm away from the emitter, so it has an extremely wide beam. Great as a āflashā for photography, but not very useful for anything else.
The goal here is to make a pocketable aspheric thrower for entertainment purposes. I donāt need 200+ kcd of throw, but I wouldnāt mind getting as much as possible out of something the size of a C8 or smaller.
Any thoughts on the best approach here? I currently have the UF-838 and de-domed XP-G2 on a 20mm star and a replacement 17mm driver and a dummy plate to mount the driver in a 20mm hole if necessary. Just not sure if I should grab a UF-T20 too, or just find and shape some copper to jam into the hollow pill and use the parts I already have.
Hi
Iāve got a uf-t20 with dedomed xp-g2. It has additional copper in pill and spring mods.I just put in a fet driver by adding a fet to a 105c like comfy chair describes in one of his posts (but not same fet, but similar specs). Now Iām thinking Iād like to see what it is like with an XML dedomed. But Iām concerned with this driver it could blow the led with a inr 20c. Could it blow the led or am I worrying for nothing?
Thanks.
The XM-L2 has a lower voltage at a given voltage so it will draw more amps, if all is done well, as it seems, you could get 7A or so. I assume a direct thermal path copper board, clamped or soldered well onto the pill? Then it should work alright. The light will get hot, but it will handle the heat, at least for the first few minutes.
I would put in an xm-l2, but only have xml on hand. Yes sinkpad, but attached with fujik. So even though the driver is capable of 10amps+ (what I have measured with basically the same driver on an srk), and the battery is supposed to be able to do 15amps, something stops it going to these levels? Sorry if thatās a dumb question. Iāve tried to read up and understand, but not quite there yet.
The XM-L has a slightly lower voltage than the XM-L2 but that should not matter much. The current is limited because a)the XM-L2's voltage at 8A is already 4.2V, add up the various small resistances in the rest of the system and you will only end up with lower current that that, b)even the best high current battery will not be able to maintain its 4.2V voltage at higher currents (see the various HKJ battery reviews). So no worries, it will be even a challenge to get it over 6A.
Btw, try to make the fujik layer as thin as you can get it, getting as much as possible metal-metal contact.
This is something you made? Do you have a thread about it? Have you tested the actual ouput results using this collar vs a Wavien?
Whatās stopping it is the Vf, while in a multi emitter/multi-cell setup the FET drivers can do up to the maximum rating of the FET / cell combo however running that high the Vf is the limiting factor in a single cell setup. Most of us see sound 5-6.5A (out of the best 4.2v INR cells like 25Rās and VTC5ās) to a single XM-L2 and about 5-5.5A to an XP-G2. You will need to use a buck driver with higher input voltage to get above that, itās just not possible with a linear setup cause the cell canāt support the increasing Vf.
From 4.2v in (using 4 Parallel 25Rās in an SRK) the highest Iāve been able to obtain is 21A to 3p XM-L2ās (which averages out to nearly 7A per emitter plus a little burn off). I do not believe anyone has been able to get a linear FET driver to do above ~7A per 3v emitter tho there are several buck drivers that can run a 3v emitter at >8A. I have a few 6v MT-G2 lights that run the same FET driver at 11.3A and also have a series light (3s XP-g2ās and 3s cells) that runs the same FET driver at 15A.
You could switch to 4.35v cells but the real world gains would be probably <.5A more. You could also switch to 26650ās or 32650ās but the real world gains would be even less.
So how did you achieve 1/10 mm accuracy? Did you use spacers?
