Kaidomain copper mounted led's
It seems you are right Old-Lumens. I removed the sst-90, hit the board with a dremel and tested it with the DMM. All results point to direct copper.
Test the board as is, the way the emitter will see it. If you have continuity then you should also have a direct thermal path. And that board is not the one they showed in the link.
Because I’m stupid and I like to do things the hard way :Sp I can find another way to mount the led, it doesn’t really bother me.
I hadn’t picked up on the board being a different colour. The specs are the same in every other way though.
It appears the white boards are sold out.
Actually, it would. Diamond, except for blue and doped synthetic, is a non-conductor and would constitute it's own dielectric layer.
i think what he is saying is that when you hit the board with a dremel , you are grinding down to the copper, and now you have no idea if it was direct to copper before you dremeled it.
If there is a separate dielectric layer, it is the dielectric that determines the thermal properties, not what it is on top of. A diamond board with no dielectric layer would not have a separate dielectric layer, just like a direct copper board has no dielectric layer... hence why on purpose I included the words 'and a dielectric layer' in there.
Honestly I was just to lazy to scratch it by hand and my train of thought was a dielectric layer would be easy to see anyway. I did a dremel scratch on the original sst-50 board to double check myself.
Sorry, my photography skills suck.
I could be wrong about this, so I am asking, should you have scratched it at all. ? If you test to see if the led goes thermally direct to copper, don’t you test from where the led would be, instead of scratching down to the copper ?
I thought that was the angle of DBCstm’s question.
You guys do understand the physics of it right?
Conventional MCPCB is just a very very thin PCB on top of a metal backing
Noctigon and sinkpad, they remove the center heatsink area (between the + and - solder points) to provide a direct solderable path of heat to the hunk of metal underneath
http://www.pcb007.com/pages/zone.cgi?a=59637
sinkpad actually punched the center portion out then pressed in a plug of copper underneath (or as above diagram shows presses a slug upwards to the base of the emitter), noctigon cuts the pcb BEFORE they machine out the stars…is one better than the other…maybe but they BOTH are heads and shoulders above the heat insulative layer of the PCB
A solution to those crappy MCPCB’s is to figure out a way to cut and remove the center PCB material and then solder directly to the star underneath
Thermodynamics
Thermal conductivity of fiberglass (standard pcb material correct?)…horrendous compared to solder
Thermal conductivity of solder
Which do you think would be “better” at moving the heat generated by the LED?
so the above star with the PCB on it made out of copper or diamond or aluminum…until the heat can force it’s way thru the very low thermally conductive PCB…it doesn’t matter what the star is made out of.
So basically there is little point filling that void in Noctigons/Sinkpads with solder and filing/lapping flat as Ive seen done? Its just a lack of faith to do so?
well not entirely no…the heat is going to travel the path of least resistance (same as electricity)…it will fan out from the center solder point then into the star, then into the pill…the beautiful thing is now it takes that teeny 1/8” square (the thermal slug the emitter is mounted on) and turns it into an effective 10/16/20mm square surface (whatever the size of the star)…then it has to force it’s way thru the RTV/epoxy which has a lower thermal conductive rating as the metal above it
The filling in and lapping just ensures you have MORE metal to metal contact rather than uneven surface
this is what it looks like “microscopically” between the star and the pill, the RTV/epoxy fills that space, yes it’s lower thermal resistance that copper or aluminum but MUCH MUCH better than static air
This is why you use a VERY thin layer of the mounting compound…just to fill the gap…NOT to create a gasket
I guess you could reflow the led straight to a big lump of copper for best thermal path. H)
Then drive the crap out of it J)
Yes, I know, I will get more heat and less efficiency with those numbers…. but I get lotsa light!
:smiley: nice!
There will be some thermal improvement by doing so. The question is whether or not it will be enough to be worth the effort. When you're looking for every last bit of efficiency and time/effort aren't at issue, it may be.
The black topped copper MCPCBs at LCK-LED are also not copper all the way through. They do have a dielectric layer on top of the copper.
I’m disappointed, but they are still handy since they are thicker than most other MCPCBs and sometimes I need a little extra height on my LEDs to get them lined up in the reflector where I like.
Scrape that center square out…fill with solder, reflow emitter back down…not as good as already made…but better than the dielectric layer
Or after cutting out the dielectric, build up the copper with electrolytic plating. I'm not sure how the +/- pads would be shielded though.
Drill a hole, poke copper rod through, whack with hammer, file off the excess bit on the back.
very nice job comfy!
