It does on the original mule PCB (the red 'JB' driver), this is the same circuit just on a new board so no reason it won't do the same here.
So very cool.
Comfy, these are the parts that I need here. I think you linked them somewhere before. The tiny13 will need to be flashed right?
Yes, MCU will need to be flashed. Add one of these to your Digikey order, it's cheaper there than ebay: http://www.digikey.com/product-detail/en/5250/501-1311-ND/745102
And then these for the rest of the stuff needed:
http://www.fasttech.com/product/1002900
http://www.fasttech.com/product/1011800
http://www.fasttech.com/product/1135300
comfy, that's the cleanest board I think I've ever seen! All purty for the pics!
I ordered the 7135 based 46 mm's because I got a ton of 7135's now and need to use them on something, and think'n I'd like to keep the SRK lights regulated, somewhat anyway - I'll still pile on 7135's, but more in the realm of 3.5A per LED. Also ordered the 17mm and 20mm FET based boards.
Comfy, that’s awesome. However, thinking of my recent experiences,
And also
Maybe I should just harvest a tiny13 that’s been flashed and reflow. My soldering is getting better since I trashed the MTG2 driver- but it’s not good. Although, my ego and enthusiasm make up for it
Well I am still getting some squeal, but this is the first one built. Time to start swapping parts and see what changes it. It was silent on the JB board but I was using a different inductor. I need to try it with no inductor, and with the other inductors I used before. I do know for sure it would be louder without the big capacitor, that's never failed to show a big improvement. This PCB is thinner than the other SRK boards which can also have an effect on PWM noise (different resonant frequency).
Another weirdness I didn't see before: after disconnecting power then reconnecting (like swapping batteries), it turns on in the lowest mode even without any input from the switch. A long press drops it down a mode and it turns fully off like normal. This is the exact same code I used on the test boards so I have no idea what's different now.
I also need to flash it temporarily with a FW that has a battery monitor mode to see if this diode (D1, the little one) has the same voltage drop as what comes on the 105C.
The capacitor isn't holding a charge by any chance and plus providing a false "on" signal to the MCU?*
- Matt
* I've put not thought into this comment what-so-ever.
That was Mattaus’s handywork on the build of the OSHPark board (and design thru Eagle), comfy and rufus giving expertise…and me just being able to cheerlead them on
That is what I did with TexasPyro 20mm Nanjg…ended up flashing it to STAR V1.1 though, it caught me off guard because I thought I already flashed it…but started getting the flashies…hah
Maybe I will just offer my services for soldering and flashing drivers (for a small nominal fee)
and OUCH on the smoking of the emitter…dang, but it happens
It’s embarrassing, but a learning curve with lots of help and support from the tutors here at BLF. I’m getting better. My patience or lack of patience is my downfall.
Nope, if I disconnect power while it's on I can see it drain the cap, as it fades down to nothing which looks different than blinking off instantly when turned off via the momentary switch. I did try shorting the cap to drain it before connecting power but it still does it just the same.
Maybe I missed it, but for the 15 mm DD FET driver, has anyone tested that FET, or assembled/tried this driver yet? Do we have a good feeling this FET and driver will work ok?
Anyone have a DigiKey listing for the FET?
The fets were used by Werner but I would not call them thoroughly tested. By itself one blew but I think that was with an 18650 so he designed his board for four but that is still testing. That size driver is meant for 14500 applications where the current available is less. It should be ok with a 10440 but might need 2 stacked with an IMR 14500. This is hypothetical at this point as I have a few but haven’t tested them yet. I can pop two in the mail if you want to try them out. I got them on eBay for less than .30 ea. I was going to try one out on a blank single mode board first but that won’t happen til the week end.
Hhmm. No rush - I ordered the 15mm boards, very cheap, so if you get a chance to try it out this weekend and post, that would be great. Probably wil be a couple of weeks before I can get to them anyway. I got a UniqueFire G10 and a Romison RC-29 which are nice quality little 14500 lights which will really benefit from a programmable driver like this. The G10 has a single mode driver with a XP-G2 in it, and the RC-29 is totally stock with the next mode memory PIA thing. I got some other 14500 15mm lights as well.
I have some of the 17s but haven't built one yet. No 15s here, don't really have a use for them.
So I tried this, didn't have any effect-
(http://edn.com/design/components-and-packaging/4364020/Reduce-acoustic-noise-from-capacitors)
So noise is not from the little cap. It's not caused by the inductor, either (still makes noise with the inductor removed completely, and the pads jumpered), though the inductor used can have an effect on the noise. So far, the quietest one is the .58uH Panasonic...
It doesn't drop the low mode as low as the .8/1.0/1.2uH parts, but you can always drop your PWM values all the way down to '1', and it's pretty damn low. Lower inductance also means it has less of an effect on the higher modes (less DC resistance).
Are there any other options for PWM frequency with the attiny13? Like, lower, where it might be outside the resonant frequency of the parts on the board?
You could try 2.4kHz, which requires changing F_CPU in the source code to 9600000 and a low fuse of 6a. Or you could leave the low fuse and F_CPU as-is but set it to Fast-PWM with a prescale of 8, which would get you around 2.2kHz, or increase the CPU speed to make it even faster (if I have all of that right).
* define F_CPU 4800000 CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
* /8 PWM: 1.176kHz ####### use low fuse: 0x65 #######
* define F_CPU 9600000 CPU: 9.6MHz PWM: 19kHz ####### use low fuse: 0x7a #######
* /8 PWM: 2.4kHz ####### use low fuse: 0x6a #######
OK, so why is STAR 1.0 silent (just now tried it for the first time (no changes other than sticking in my favorite levels, 0,2,6,18,54,130,255), using same 0x75/0xff as before), but minimo is noisy as hell? I don't understand the code well enough to translate between the different versions to pick out which difference causes the different behavior...
STAR uses Fast-PWM at 18.75 kHz and MiniMo uses Phase-Correct at 9.4 kHz (just like Luxdrv and BLF-VLD). That 9.4 kHz seems to make every setup whine, and Fast-PWM makes it silent. But I thought the FET setup didn't work with Fast-PWM? Or did your hardware changes now allow it to work?
I don't know, I just took the original STAR v1.0, plugged in my PWM levels, flashed it using 0x75/0xff, and it works.
