Fasttech - interesting new products - Flashlights, chargers, batteries and DIY and knives - please no discussions.
1488 posts / 0 new
TSellers
TSellers's picture
Last seen: 10 months 3 days ago
Thanks for the head’s up. I ended up grabbing a couple of 5R’s, and did not realize that the 3R has a battery setup similar to a cell phone.
If you go by the FAQ written by Ed Griffin, at the bottom of page 9, it sounds like if you have the correct battery, it should still have a protection IC in it, but he also confirms that the base has no controller, so it’s a good head’s up for anyone that may have grabbed those units from Fasttech. Anyway, here is some more information from that FAQ on this subject that may be of interest to some:
Edit: I shouldn’t have said, “written by Ed Griffin” (he owns Wouxun.us), it says on the cover it was a collaboration project, so it would be more accurate to say he distributed it (and probably had a large part in the collaboration as well).
Regards, TS
Buwuve
Buwuve's picture
Last seen: 5 years 6 months ago
After a longer time without any new interesting products here are a few nice products:
Some different stoves of Fire-Maple. One for fuel and the others for gas:
Fire-Maple FMS-108 Camping Stove Gas Burner output power up to 3500W, price $71,29  My link - non aff-link
Fire-Maple Spark FMS-121 Wind-Resistant Remote Gas Stove firepower 2900W, price $38,53  My link - non aff-link
Fire-Maple FMS-100T King Kong Titanium Gas Stove 2450W, price $60,36  My link - non aff-link
Fire-Maple Turbo FMS-F5 Remote Fuel Stove 3200W, price $60,60  My link - non aff-link
Light up the darkness.
Buwuve
Buwuve's picture
Knives:
Enlan M027 Stainless Steel + Pakkawood Folding Knife 54mm blade, $9,36. My link - non aff-link
the bigger brother Enlan Bee EL-05 Stainless Steel Folding Knife 72mm blade, $13,75. My link - non aff-link
Enlan Bee EL-06 Stainless Steel Pocket Folding Knife 92mm blade, $16,80. My link - non aff-link.
This is a big and nice knife. I have it since a few weeks and it works really smooth. Fasttech also have the black G10 version, with non coated blade for $15,44.
Ganzo G203 Stainless Steel Multi-Tool, $21,50. My link - non aff-link
I will recommend the larger models of the 300 series more, because they are more stable, but cost $15-20 more.
Sanrenmu 9054MUC-GP No Lock Stainless Steel Folding Knife 83MM blade. The GP is the green handle version the GH the black. Price $13,16. Teutate buy this on ebay for $18,90 and show some more pictures here. Important thing: It hasn't a lock, but it's to long for UK (3") if you do not modify it. Take a look at the thread of Teutate.
Chloe
Chloe's picture
Last seen: 6 years 4 months ago
Ah, they now have the ‘strange fish’ knife! Thanks, Buwuve.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 6 months ago
Buster Friendly wrote:
I know this is not a radio thread however it must be said, if you do buy a uv-3r under NO CIRCUMSTANCES should you use the charging stand. It simply wires 5V strait to the li-ion battery.
DO NOT USE IT!
You CAN use the charger into the charging port on the side of the radio though, it is regulated though a ‘proper’ li-ion charge controller.
You know this how?
I have the UV-5R and it works like a champ…also the MTC UV-X4 which is a clone of the UV-3R, has a 5vdc charge port on the side (little spade that plugs in with a USB connector on the end)…maybe it has a li ion charger circuit inside
P.S. Open source programming program that is ALOT better than the chinese version CHIRP
Quote:
CHIRP is a free, open-source tool for programming your amateur radio. It supports a large number of manufacturers and models, as well as provides a way to interface with multiple data sources and formats.
Oh and this will also help too
http://radiofreeq.wordpress.com/2013/11/05/program-your-vhf-uhf-transcei...
TSellers
TSellers's picture
Quote:
You know this how?
One way would be by reading the Third paragraph of the image of Ed Griffin’s FAQ shown in post #1141. Another would be to Google it, which seems to indicate that is correct.
The Third paragraph of the image of Ed Griffin’s FAQ shown in post #1141 addresses that question.
And I suppose someone will mention it anyway, programming that frequency list into your Baofeng would be illegal, but in reality your chances of getting into trouble for doing it are almost NIL. However, unless you live in the USA, many of those channels would be useless to you anyway. The best way to summon help is call 911 on your phone, and if there is no cell reception and you have to use a radio, then you better be able to hit the local repeaters (for which you need to know not only the tones codes required to activate them, you also need to know the duplexed frequencies, and whether they are Wide or Narrow Band) The only duplexed channels in that are in that list are token GMRS ones that probably would not exist where you are, but you can check here you live in the USA.
Another note regarding those Fire Maple Stoves linked above. Looks like he missed the FMS-118. Even though it has a pre-heat tube on it, they do not work all that well in the cold because the tube is too small, so it splutters almost as soon as you invert the cannister. It looks like they added a second tube plus shielding to the FMS-100T, so I suspect it should perform a lot better in cold weather.
Regards, TS
8steve88
8steve88's picture
Last seen: 5 years 7 months ago
Thanks for the heads-up Buwuve, bloomin’ typical, I ordered two of the “strange fish” knives from another source for $19.99 each. I really should have waited but I’d only just put in a product request in, not that that makes any difference if the copy/past answers you get are anything to go by.
I like the look of that Enlan/Bee EL-06 as well but there was a bad review on youtube saying the scales looked painted with the camo and the thumb stud was very hard to use and uncomfortable, looking at the position of it in the pictures on FastTech I can see that it might take a bit of dremelling to uncover it a bit. It is a good looker though.
bibihang
bibihang's picture
Last seen: 1 day 11 hours ago
I think Fasttech is no longer interested in Flashlight products. If you notice all the new arrival products from 24th February onward are e-cig related items.
WarHawk-AVG
Daggumit…it was FT fault for getting those flashlights in while I was ordering my vaping stuff that got me onto this new hobby…they BETTER not bail on us flashlight folks!
Sirius9
Sirius9's picture
Last seen: 1 week 2 days ago
or what? you will stop smoking Big Smile buaahahahaha
Smoking is much better/probitable addiction, users cannot stop buying new e-liquids and they are not as demandable as flashlightoholics also Smile
Buwuve
Buwuve's picture
EVVA 26650 3.7V 4500mAh Rechargeable Protected Li-Ion Batteries (2-Piece) max. 13A continuous discharge current. Price for a pair $24,98 (with BLF $23,73). My link - non aff-link
Not a flashlight, but it produces light: Fire-Maple FML-601 Camping Gas Lamp 80 LUX / 1500W firepower. Price $22,90. My link - non aff-link
Security Tracker LED Pet Collar Pendant Light 3*LR41. Price $2,11 My link - non aff-link
Buwuve
Buwuve's picture
Roche F6 XM-L2 U2-1A 3-Mode (high, mid, low) 1700mA  1*18650 with a clip and two glass breakers. Fasttech wrote neutral white and 700lm, but it is a U2 1A (cool white) and 1700mA will not produce 700lm. I think 500-550 would be more realistic. But it has high, mid, low without strobe and sos Smile Important: It supports only short batteries - round about 67mm. Most protected will not fit.
$23,96 (with BLF $22,76). My link - non aff-link.
Buwuve
Buwuve's picture
This both are high drain batteries and of course unprotected like any other high drain battery on the market. But they are really shotz (round about 65mm) and perefct for modders and vapors.
LG18650 3.6V 2500mAh Rechargeable Li-Ion Batteries (2-Pack) 30A continuous discharge / 35A peak discharge. Price: $14,69 (save 5% more with BLF) My link - non aff-link
US18650VTC5 3.6V 2600mAh Rechargeable Li-Ion Batteries (2-Pack) 30A continuous discharge / 60A peak discharge. Price: $15,33 (save 5% more with BLF) My link - non aff-link  --> Sold out at the moment. I think many people want these and FT has only a few. Visit the page in a few days, maybe it will be in stock. It was the same with the Sony VTC4 (with only 2100mAh).
Buwuve
Buwuve's picture
A few more convex lenses are available. I put in only one lin. You can choose each size with the drop down menu on the fasttech page (it's under the price). Use BLF to save 5% more. My link - non aff-link.
Plano convex, 5-90 degree, most of these 98% light transmittance.
43mm ($2,49), 44mm, matte, 96% light transmittance ($2,69), 50mm ($3,50), 50,6mm stripped ($3,13), 53,7mm ($3,46), 63mm ($3,06), 70,8mm ($6,08), 73,5mm ($6,57), 73,8mm ($6,06), 74,2mm ($5,93).
Large biconvex lenses, 98% light transmittance.
102mm, 14,5mm height , without edge ($10,70), 101,9mm, 16mm height , 3,3mm edge ($10,86).
djozz
djozz's picture
Last seen: 2 days 2 hours ago
garrybunk
garrybunk's picture
Last seen: 1 month 4 weeks ago
Wow!  Just wow!  No battery indicator? Not interested.  What's the runtime like, 10 minutes?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
mk96
Last seen: 1 year 9 months ago
Quite ugly, isn’t it?
keltex78
keltex78's picture
I like it! I want to fabricate that into a headlamp! Cool
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
djozz
djozz's picture
this light is sacred, it goes on top of your miniature house-temple and should be praised.
mfpmax
mfpmax's picture
Last seen: 6 years 6 months ago
That would definitely call for a LiPo pack upgrade.
unknown00101
Literally a headlamp. You would have to ratchet strap it to the top of your head like an ultra lumen helmet. I’m busting up laughing here imagining how hilarious it would be to see someone walking/riding around with one of these strapped to their head. Big Smile
You could have an extended switch running down your neck/shoulder/arm to your hand to switch into turbo to blind people who laugh!
Maybe we could get one with more emitters/heads and it could be capable of communicating with extra terrestrials like demonstrated in Independance Day.
(I actually do like the look of it for a handlebar bike light. If I rode at night I would be tempted to get one, your ‘bright lights’ could turn on all emitters and dim/regular could be 1-3 of them, pretty neat if doable imo)
DayLighter
DayLighter's picture
Fasttech is able to ship batteries again? Flat Stare
The only way to do a great work is to love what you do.
JohnnyMac
JohnnyMac's picture
A few new lights at FT today.  These two caught my interest...
Solarstorm SC01  XM-L2 AA/14500 2-modes (High & Infinite dimming) for $15.17
LZZ-01 2*XM-L/26650 for $25.48  This one has me sorely tempted as a mod base for this price.
ChibiM
ChibiM's picture
Last seen: 9 hours 31 min ago
Wow, that solarstorm at that price....
now waiting to see if thats the same as the Palight X4!?
bikenber73
bikenber73's picture
Muto
Last seen: 25 min 30 sec ago
Check this out;
https://www.fasttech.com/products/1421/10007674/1663902
Now read the specs for the AC adapter vs the charger cradle?
Sounds like the cradle can do more amperage if you use a better power supply?
Both are DC current.
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Muto
https://www.fasttech.com/products/1/10007668/1663800-lzz-01-2-cree-xm-l-...
Butt Azz ugly and looks like 3 different shade of ano.
Pass.
Buwuve
Buwuve's picture
There are also some Luminus LEDs:
FT wrote aluminum base, but the picture shows copper
Luminus SS-T50 15W 1200LM cool white 6000-6500K LED Emitter 20*1.7mm base,  4500mA. Price $12,33 (with BLF $11,71). My link - non aff-link
Luminus SS-T90 LED Emitter 20*1.7mm star base / 3.2-3.8V / 8000mA 30W 2300LM: Warm white  3000-3200K, neutral white 4500-5000K LED emitter, cool white 6000-6500K LED Emitter. Price each: $20,48 (with BLF $19,46).
Jerommel
Jerommel's picture
Really sorry to see FT go (almost) completely vape..
Many things for flashlights I really miss in their stock..
TexasToasted
TexasToasted's picture
Last seen: 2 hours 56 min ago
JohnnyMac wrote:
A few new lights at FT today.  These two caught my interest…
Thanks for posting that, JohnnyMac. I missed out on the group buy for the MAXToch DX21, but I like the Fasttech version even better since it has the tailswitch.
