Oshpark Projects
I just browsed over the the last pages, so I didn’t get all details, but: is it right that that reset pin on the attiny is floating?
If yes, please try tying it to vcc with a 4.7k …10k resistor. That can easily cause such strange behaviour.
The thing is every board I have ever created with an ATINY chip (13 or 25 for me) has been setup exactly the same way. I have never experienced any of the problems that are being described here. Not saying it's right or wrong, just saying it's weird that Dale/Comfy are having issues. Happy to pass my BRD files onto anyone who wants to double check my work; it's entirely possible that I've made some stupid mistake.
- Matt
I will say this, on my joule thief build the .brd file I uploaded to OSHPark I got from alxsmith, some of the traces just went away, he was using an older version of eagle, but he fixed it with the latest…I think you said you were running 6.5.0 right?
Sure, no doubt it might run forever without any problems that way. :wink:
Thing is, the reset input is not designed or supposed to be left floating. It can change it’s potential through coupled-in noise through parasitic capacitance or inductance on the board, esp. in high current switching environments like those drivers. Even some dirt or flux residue can cause troubles. That’s why one should tie it to a potential like vcc (but with a high enough pullup resistor that the programmer still can pull it down. )
I would strongly suggest to implement that in future designs, even if it is not the problem in this case.
It very well could be the problem (that random blinking stuff could be resets), a workaround costs a few cents at best, so I would say it is worth a try. If you can exclude it from the list of possible causes, it was worth the 5min work I think. :slight_smile:
This may be a long shot but have you tried checking the board for shorts? At this point I may also try measuring resistance of traces vs. the 105C. I think that dave_ may also be onto something.
I have never needed an external pull-up on the reset pin, the internal pull-up sufficed. However, in noisy circuits, an external pull-up (typically 10k, maybe even only 4.7k, but not less than that) is often recommended, because the internal one is quite weak (~50k). My guess is that the FET switches much quicker than the AMC7135, which indeed implies more noise. It might help to check the reset pin with an oscilloscope.
A resistor between MCU and gate is also often recommended.
I'm not into DD, so haven't tried.
Well, 50k actually would be a lot better than what I recalled, but could still be to high in this situation. I’d give it a try.
Would comparing the code that works to the code that doesn't help to nail down what the issue is? I don't understand it well enough to know what the differences translate into in actual use...
http://75.65.123.78/fw/luxdrv02.txt (doesn’t change modes reliably)
http://75.65.123.78/fw/starv1.1clicky.txt (works fine)
http://75.65.123.78/fw/minimoandFFK-6mode.txt (works, but very noisy)
http://75.65.123.78/fw/starv1.0momentary.txt (quiet)
I'm using fuses 0x75/0xff when flashing all of them.
Also, for a temporary test, I can use a plain jumper wire from Vcc to RST instead of a resistor, right? Just don't try to program it with that in place (it would block the clip anyway)...
Here's a mouseover of the 17DD showing what's underneath
The diode could be rotated about 30* CCW to free up a bunch of space for fatter traces in & out. Also looks possible to pop in a via near the RST pin and add a resistor on the spring side of the board, if it turns out that's needed.
That's actually a very good point. Every FET based circuit I've ever worked on prior to this (so um...one lol) has had a 100ohm resistor between the MCU and FET gate. I think the reason I skipped it here was because the original SRK board never used one either, and I was lead to believe it work fine? That being said I know what it's there for so I should have included one regardless.
10k pull up on the reset pin to VCC will now be included on all my boards by default.
When I get the time to update some of these boards (and some sort of testing prior would be good) I will update the OSHPark projects.
Anyone who has ordered any of my boards and is experiencing problems, can you please PM me?
- Matt
The JB driver with the single 2SK4212 FET didn't use a resistor to the gate, and worked fine with any of the right firmware versions and before any mods using the stock unknown MCU and also after the piggyback 105C was added... it still works without the resistor on the new 46mm version, the only issue with that one is the noise from certain versions of firmware. Lack of a resistor shouldn't affect the smaller board if it doesn't also affect the larger one, I would guess.
17DD shows no change with RST jumpered to Vcc, still erratic mode switching with the luxdrv code.
Is there a pull-down resistor on the FET gate? Without one the FET could come on between the time the processor is powered up and it initializes the state of the output pins. Try something around 1K to 10K from the FET gate to ground.
None of the other boards have needed a pulldown on the gate using the same components.
I've tried jumpering various stuff at random: from B+ to the diode, and from the diode to MCU's Vdd, neither made any difference. But I then moved the jumper to go straight from Vdd pin to B+, bypassing the diode, and it now changes mode like it should, doesn't do that weird random strobe/morse code crap, doesn't change 2 modes when it should only do 1, etc. The diode isn't on backwards, could it just be a bad diode? I doubt it, since the battmon mode in luxdrv gives the correct number of blinks that matches the input voltage.
Try the pull-down…
Maybe not a bad diode, but it is a different diode, right? (than the one you use on the 105C)
Supposed to be the same diode, or at least functionally interchangeable. http://www.digikey.com/product-detail/en/ZLLS410TA/ZLLS410CT-ND/1767188
OK, progress, of a sort: the old standby version of luxdrv works properly with the diode removed & replaced with a jumper.
edit: Of course, the voltage monitoring is off without the drop from the diode, it gives 13 blinks for a cell with only 4.1v. But at least this is getting somewhere.
So all it does is remove the reverse polarity protection otherwise
I wonder if a switching diode would be better
http://www.ebay.com/itm/like/121300037210?lpid=82
