I had 3 that all seemed to be working OK but you guys got me curious. I pulled the guts out of the plastic housing and broke off the mini-USB port. I did try to be careful. My skills aren’t up to re-attaching that little thing. Pretty fragile little part. I pulled off the copper pad on one of the 4 feet anyway so doubt I could have ever gotten a decent connection.
The law do diminishing returns. It goes both ways.
As you try to increase the performance of an item, the cost goes up with less and less improvement.
On the other end, as you try to lower the costs of an item, you reach a point were each cost savings that you implement impacts the performance more and more until a point is reached were functionality is lost.
So I got my couple black ones of these, both with FM6316CE, and not too impressed. It seems now & then I have to (re-)learn this, but yes one almost always gets what one pays for:) And when something appears “good” & perhaps popular (e.g. ETA9635 implementation), you can bet someone will try to cheapen it, maybe even below usability (like dchomak related).
What mine does OK: Charging its battery (at least it cuts off about 4.2v), RED LED during charge then BLUE when done. Charging iPod & iPad at the max rate I’d want the little thing to do.
What mine doesn’t do well: Cutting off battery (I pulled plug at 2.3v) or indicating battery state during discharge (no LEDs lite on mine during discharge). Controlling heat, as WarHawk noted the parts on this get hot at high or continuous discharge rates - in particular the SS34 diode, a bit lesser for the chip & coil.
So can’t use unprotected cells in mine due to the apparent lack of low-voltage cut-off…. Unless maybe tacking on one of those cheap Mini DC Red LED Panel Voltage Meters on the box to keep an eye on it.
IMO if you can assure your purchase has ETA9635 it may be fine, otherwise stick to proven/tested stuff.
Not cutting off that you noted really disturbed me. So I checked mine. (It just never occurred to me to check for this.)
My black unit has the 6316. When using it to charge a device, the 6316 will suck the 18650 all the way down to zero.
My 2 others have the 9635 and cut off discharging the 18650 at about 2.75v - 2.80v. It’s not actually a sharp cutoff but is gradual decline.
So to repeat what others are saying, the units with the 6316 are bad.
The units with the 9635 are good.
Shoot. I just I should be somewhat happy that I only ordered 1 black one (I think) when I made my 2nd order for a whole bunch for gifts :~ . If I don’t bother to fix that one than maybe I’ll only keep that one for myself and use it sparingly (+ safely.)
In any case, thanks for the good detective work guys! It helps keep oblivious people like me safe with things like this…
OH SNAP! I forgot I have like 3-4 of those little .36” voltmeters just laying around…going to be modding one of mine to monitor the voltage…
I snapped the USB micro connector on a Xtar MC1 3x times…carefully soldered it back down…well last time it came off I got pissed and used a flathead screwdriver and stripped the board…just shoved the components off like a bulldozer, then soldered a pigtail and one of those thin TP4056 boards on it and super glued the base back on…and wouldn’t you know it…works like a champ (broke the daggum spring tonight and said to hell with it…ain’t gonna fix it again…just cut the charger module and chucked the whole thing [I really do like those slider charge holders though…uggh…recovering and will try to mod it with a pen spring or something] {correction, the bottom flexed and the spring jumped off the round holder…I cut off the pigtail in error…DOH!:smiling_imp:
I also built a 4x 1s4P board with the voltage meter on it, I charge 1 battery at a time or ALL 4 out of my SRK (I know better than mix/match different level batteries on a single channel)
I’ll mod one of these little ones and do a full discharge and see where it stops and then do a full charge to see where it stops…I can say the ones that I put the silicon/RTV run more “stable” but like I said, I’m no electronics engineer
Looks like there’s confirmation that the units w/FM6316CE implementation are unsafe for use with unprotected cells, they’ve no low battery voltage cut-off or indication. And as OP/chiefinspectorfinch indicated, and the tight fit backups up, no (few?) protected cells will fit.
chiefinspectorfinch - Please consider amending the first/original post of this thread with this info. I, like others, do not always read review threads to the end & might miss this important info. We also cannot be sure that ordering a white one will always get you a safe/ETA9635 one.
Two ways to tell you’ve an unsafe or FM6316CE one:
1) you don’t have to take it apart & risk what happened to flydiver… Here’s a (crummy) photo of the top side of my unsafe/FM6316CE - compare to equivalent/last pic in first post in this thread (e.g. the black 0 ohm resistor next to soldered spring (likely a cold solder joint BTW)):
2) a simple run-down test w/DMM & clip leads w/unit charging something that’d use all its power. Of course be VERY careful not to short cell.
IMO not sure you can fault the seller of bad ones if the transaction is good otherwise. He’s likely not the designer, he’s just pushing product. Perhaps informing of this thread / asking for one w/ETA9635 (top side looks like chiefinspectorfinch’s photo) would get you somewhere but I doubt it.
Again best to stick to proven/tested stuff (e.g. see HKJ’s site). But as even tested products can change over time guess sticking w/names/reliable suppliers OR maybe carefully comparing photos of guts is something.
I was alarmed when I read this so I checked my powerbanks and found that one of the yellow banks (I have 10, 2 per color) had 6316. I charged this particular powerbank 4 days ago and placed it aside for future use. When I took the readings, the new unprotected Samsung ICR18650-28A reads 0.96 volts which means that it discharged by itself and drained the cell below safe levels.
Now I’m not sure whether I should recharge this cell but I’m pretty sure I’ll never use this particular powerbank again. Will it be safe if I recharge this drained lithium ion using a NiteCore i2? :~
Well I went ahead and charged the Samsung ICR18650-28A with 0.96 volts using my NiteCore i2 and observed that it reaches 3 bars (full charge) from 1 bar in a few seconds so I immediately removed it from the charger fearing that something bad might occur.
Seeing Nightbird95’s post I just tried to measure parasitic draw for my unsafe/FM6316CE unit & it’s below resolution on my Fluke 111… But that’s not saying much, it doesn’t resolve low enough. So parasitic draw is another possible problem w/these units.
In doing so I found out how/why these unsafe/FM6316CE ones fail under heavy (current) draw - They don’t appear to limit it. Trying to charge an IPad just now I measured 1.9A draw, about double the 1A limit per FM6316CE datasheet. BTW the datasheet also expounds WRT low parasitic draw (16uA) & protection (incl under-voltage), so guess we’re just looking at horrid/faulty/dangerous implementation.
Guess my IMO above should change - A seller informed of this should refund & cease selling the unsafe/FM6316CE ones.
I also informed the shop where I bought it (eBay Shop from “keyzone”) with a link to there, also to get a refund for the black one that was defective after 5mins.
I would guess that nobody really gets hurt, or rather equally bad for both chips. Only the battery cells will get damaged with the FM6316 because of the discharge issues, but they won’t get shortcircuited or overcharged. At least from the current information we have. Of course both of these chips/designs could still have some other issues. When looking at the poorly detailed datasheets it looks like “anything could happen” ….
// Edit: Ok afterall the datasheet of the FM6316 seems to be actually more detailed than the ETA one, at least what you are showing here and what I found for the ETA. And like you said, maybe poor implementation, wrong current limiting resistor? I will check mine at another time…
0.96v is essentially dead. It doesn’t take much to push them back to a much higher voltage on that steep part of the discharge curve. If you can hook it up to a low volt/low output dumb NiXX charger for about 5-15” then check it again. If it’s up to 3.0v or higher then try the i2 again. Watch it carefully.
If it won’t take the charge > discharge and trash.
If it will > mark it clearly and consider it a ‘wounded’ cell.
If you don’t care for the risk (there is some) you should simply discharge and trash. If you aren’t sure > trash it. Better safe than sorry for a few $$.
Thanx for the tip flydiver. It now has a big red asterisk mark.
I charged it with the i2 (it wont fit the NiMH charger and my other charger is an i4 which has higher output) for several minutes and was in the 2-bar range when I removed it to get the voltage reading - its 4.05 volts. I guess this cell can still be fully charged then.
In the latest AliExpress sale, I ordered 20 of these to give out to people. I ordered the white ones, but if they come with the 6136 chips I will be filing a dispute. Because the implementation of the 6136 is just laughably bad.
I just checked for parasitic drain on the 1, 6316 that I have.
With a fresh cell (4.15V) the drain is 17 uA
But a with a damaged cell (1.92V) the drain is 111 uA.
I also confirmed that the 6316 will attempt to give more than it should . An iPad received over a 1.7A (they need 2.0 ) and a GPS unit for my car got 1.7A. Both are too much for this little unit. Chips started to get hot very quickly.
It could be OK if it was a newer cell and you caught it quick. The older and the longer at very low voltage the more the damage. Damage will first show up as higher resting drain and lower performance under high draw.
