Seeing Nightbird95’s post I just tried to measure parasitic draw for my unsafe/FM6316CE unit & it’s below resolution on my Fluke 111… But that’s not saying much, it doesn’t resolve low enough. So parasitic draw is another possible problem w/these units.
In doing so I found out how/why these unsafe/FM6316CE ones fail under heavy (current) draw - They don’t appear to limit it. Trying to charge an IPad just now I measured 1.9A draw, about double the 1A limit per FM6316CE datasheet. BTW the datasheet also expounds WRT low parasitic draw (16uA) & protection (incl under-voltage), so guess we’re just looking at horrid/faulty/dangerous implementation.
Guess my IMO above should change - A seller informed of this should refund & cease selling the unsafe/FM6316CE ones.
I also informed the shop where I bought it (eBay Shop from “keyzone”) with a link to there, also to get a refund for the black one that was defective after 5mins.
I would guess that nobody really gets hurt, or rather equally bad for both chips. Only the battery cells will get damaged with the FM6316 because of the discharge issues, but they won’t get shortcircuited or overcharged. At least from the current information we have. Of course both of these chips/designs could still have some other issues. When looking at the poorly detailed datasheets it looks like “anything could happen” ….
// Edit: Ok afterall the datasheet of the FM6316 seems to be actually more detailed than the ETA one, at least what you are showing here and what I found for the ETA. And like you said, maybe poor implementation, wrong current limiting resistor? I will check mine at another time…
0.96v is essentially dead. It doesn’t take much to push them back to a much higher voltage on that steep part of the discharge curve. If you can hook it up to a low volt/low output dumb NiXX charger for about 5-15” then check it again. If it’s up to 3.0v or higher then try the i2 again. Watch it carefully.
If it won’t take the charge > discharge and trash.
If it will > mark it clearly and consider it a ‘wounded’ cell.
If you don’t care for the risk (there is some) you should simply discharge and trash. If you aren’t sure > trash it. Better safe than sorry for a few $$.
Thanx for the tip flydiver. It now has a big red asterisk mark.
I charged it with the i2 (it wont fit the NiMH charger and my other charger is an i4 which has higher output) for several minutes and was in the 2-bar range when I removed it to get the voltage reading - its 4.05 volts. I guess this cell can still be fully charged then.
In the latest AliExpress sale, I ordered 20 of these to give out to people. I ordered the white ones, but if they come with the 6136 chips I will be filing a dispute. Because the implementation of the 6136 is just laughably bad.
I just checked for parasitic drain on the 1, 6316 that I have.
With a fresh cell (4.15V) the drain is 17 uA
But a with a damaged cell (1.92V) the drain is 111 uA.
I also confirmed that the 6316 will attempt to give more than it should . An iPad received over a 1.7A (they need 2.0 ) and a GPS unit for my car got 1.7A. Both are too much for this little unit. Chips started to get hot very quickly.
It could be OK if it was a newer cell and you caught it quick. The older and the longer at very low voltage the more the damage. Damage will first show up as higher resting drain and lower performance under high draw.
That’s what I don’t understand…per a translation of website pertaining to the FM6316CE
If it was working as designed these chips “should” thermal/current limit to 1A and charge the li ion with the correct CC/CV…but alas…it appears that either a bad design or bad components on the board…unknown at this time till someone with ALOT better test equipment can see just what these boards are doing…hmmmm
So far all 4 of my other FM6316CE driven boards are doing what they are supposed to do on charge…all of them give blue on full charge, using one of those .36” voltmeter I get 4.2 on the readout, and on power out they run whatever device just fine and don’t get warm, the one black one however smoked after a few hours (I need to get a USB doctor module)
I have a similar type unit, but it is a cree flashlight, with the USB input and output on the tail, where a metal plate rotates.
I’ve used mine to top up various android and windows phones, and it works, but if I were relying on it for charging, I’d probably skip the flashlight, and go for one of the 4 pack cases, that are < $10. Also, makes a great storage bin for charged batteries.
Now if those 3-4 emitter x 4, (Skyway, etc.), had USB chargers on them, those would be very interesting, but the on/off switch makes those lights useless for my needs, and rather large diameter wise.
I bought one of these http://www.ebay.com/itm/350919777680?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649 and probably paid too much. First I was hating on it. It was totally dead until I found a momentary micro switch inside and pushed it. That brought it to life. It came with no instructions. I filled it with laptop pulls and it seems to work great. I don’t know if it’s the full 2A, but it charges my Galaxy S4 fast and that uses a 2A charger. A 1A charger on the S4 is takes forever to charge it so I’d say 1.5A-2.0A at least. It also charges up ok off a PC USB port or any good MINI USB charger connection. I don’t remember if I used USB 2.0 or 3.0 port. This is just a FYI. I could review it, but I imagine there are better out there. Heck, this same one is probably on other sites for $3.99
It is a brand new Samsung ICR18650-28A and it should have stayed at 0.96 volts for not more than 4 days because I charged it 4 days prior to checking my powerbanks.
I’ve finished charging it to 4.18 volts and I’ll just place it aside for a while. If it looses its charge on its own after a day or two then I’m throwing it away.
If you want to check a cell for leakage, try watching it when it is around 3V. The discharge curve is MUCH steeper there and you will be able to notice the leakage more readily.
(Remember when that cell originally discharged to 0.96V? It didn’t take much to get it up to 2.25. That’s why it is best to check for leakage when the cell is discharged.)
I’m saying that 4 of the 5 I got with the 6316’s are working fine…one of em smoked in a day
All of mine have the 6316’s (I ordered mine from a different company that buyincoins
Could be just crappy China QC or bad chips…who knows
I did put the .36” voltage meter on one of my black ones that was working after I drained it down to where it would quit charging…stopped at 3.3, charging stops at 4.2 [it is also one of the ones I put a RTV blob over the IC…but who knows if that is the reason…might just cause it to smoke too]
The reason I asked is because my 6316, the one that will discharge all the way to zero stops at about 2.8V when charging an iPhone 3GS. That is the iPhone refusing any more current. So I suppose one could get a false sense of security by testing the discharge characteristics with a device like the iPhone. That would be a “gotcha” just waiting to happen.
To test the discharge characteristics of the 6316 and 9635 I used an 82 ohm resistor spliced into a USB cable. The 9635 stops at about 2.75V, the 6316 goes right on down to 0.
