Oshpark Projects
When I hooked it up to my big jumper cables and the car battery, it got difficult to see anything for all the smoke, but the emitter still didn’t shine. Oh well. :stuck_out_tongue:
See how much I learned? Know how long I’ll remember any of it? lol
Wish I had some sort of excuse, but Stupidity is about all I can blame it on. But hey, I got there in the end…that counts for something doesn’t it?
So, now y’all are probably gonna tell me that I should open up my M8 and C8 and 7G5 and L2P and fix them with the resistor between the PWM/FET, right? Scares me, they’re doing so well…do I HAVE to?
Nope, no need if they work with the firmware you have on 'em. For some reason the FET stuck on the 105C board doesn't have the issues with mode changing/acting goofy, that seems to be only on the new boards. Which is really confusing. It's not because of traces too small, I jumpered over all of them point-to-point last night and it made no difference whatsoever.
Could it be something about the different MCU - the SSH we're using here instead of the SSU that comes stock on the 105C? Maybe even something undocumented, or not listed in the main specs but hidden away somewhere in the datasheets?
I was playing with the test emitter, still using the lap pull 18500, and it was working perfectly. I held different levels with no problem, switched easily and repeatedly and did everything but run it on high for any great length of time. While my test emitter is mounted on copper in a fairly heavy aluminum pill, just didn’t see the need to run it prolonged at high level.
I did want to see if moon mode works. (Read, Oh Ohh!) So I soldered the #2 position to the mcu and tried it. Nada. Not even smoke or sparks. Simply nothing at all. I removed that jumper and still nada, nothing, zip, zilch. That was the ONLY thing messed with, and removed it still is non functioning.
My head hurts.
You' re a hero, Dale, going through all this and solder your way to victory, and so is your little driver board
Actually, I left Victory behind…I used to live on Victory St. No lie!
I went back to the test rig and looked closer at the board, the tiniest of slivers of solder was still between the 2 pad and the mcu, so I picked that off with tweezers and it now works again! The number 2 position, engaged, kills it dead. Open, it works fine in 4 modes. What’s up with that?
Looking back at the pics that Comfy posted, with a mouse-over showing where the traces are…that “star 2” position grounds the PWM leg. Why?
Where do I find information on what the “Star 2, 3, 4” are for?
The Star 2 is supposed to go to leg 5 of the MCU, not 6. Leg 6 controls PWM.
Borrowed this from Comfy earlier in the thread.
Might be so low that it “looks” dead but really isn’t
I have a cheapy XM-L that I flashed STAR V1.1 on a true 105C…in moon mode, it lights the LED, but just enough to make some light…you can look at the emitter and NOT hurt your eyes…any other setting and it glare blind yourself
Since the PWM of moon mode is like 3-5 of 255 the FET might not be able to open fast enough…thus no current flow
Correct, there's a mistake in the solder mask. Just scrape off another little spot above pin 5, there's a big ground plane above both pins.
Also, the old 105C 'napkin diagram' pic has the stars numbered from right to left, instead of left to right. I always count the dummy that goes nowhere as #1.
Hmmm, 28 posts since I last got on here.
Can someone summarize what I need/should/could change if possible? And on what boards?
- Matt
EDIT: I see now. Add provisions for two resistors on the FET gates on ALL FET based boards. If they fit....if they don't fit then what (thinking the Tiny15 just won't be possible)? I'll also fix of the P1/2 pads on the SRK FET driver. If anyone has been financially put out by some of these minor oversights please PM me and I'll replace your boards with new ones for free.
I'd like to see an in-line resistor pad (0805 SMD) for the FET gate, possible a pad for a pulldown resistor for the FET as well. Maybe two versions? I know that some would like the simplicity of using without any extra resistors or jumpers, but they seem to offer some benefit for some situations.
0805 resistor between GATE & GND (easy), 0805 resistor between PB1 & GATE (erm, not so easy, at least on the 17mm). I guess all of them using the TO-252 FET need those, the 46, 20, & 17mm.
17DD has the ground pad for pin 5/star 2 over pin 6 instead, just needs a tweak of the solder mask (might already have been done on the rev.2 boards, I haven't looked yet).
SRK FET board could really use a change to the switch input pads, something like this
I don't think the tiny little FET on the 15DD board needs the resistors, same as 7135s don't need them. I haven't pulled up the datasheet on that FET though.
Pfffft, stop that. We're participants, not customers. lol.
No, the FET will open at lower PWM values than when using 7135s. They usually don't work at 4 or less, the FET works all the way down to 1.
Matt, got any ideas as to why the SRK & Nanjg PCBs work without the gate/pulldown resistors, but not the 17DD? There's got to be some logical explanation. I think the only trace I didn't test with a bypass wire is the one from PB1 to the gate, but it's probably not that since the SRK one is the same width but about 4-5 times longer.
Mattaus, no worries man! We are all grateful (at least I am) for all of your hard work. You don't owe us anything at all.
I'll review the 70N05 boards tonight and see if anything sticks out as to why the 17DD is being such a PITA. I'm guessing no one has tried the 20DD yet?
I'll also make the others changes Comfy mentioned.
WarHawk, I had 2 star engaged to the PWM leg, grounding out the PWM. Once that jumper was fully removed it worked again.
BUT, I soldered leg 5 to ground and had the same 4 modes, moon wasn’t engaged by doing that. So I don’t know what’s going on there. Took that off and it’s still working fine in 4 modes.
Here’s some numbers for the crunchers out there. This test emitter is, I believe, an XM-L2 T6 3C on a 16mm Noctigon glued to a 1/2” thick copper insert in the HD2010 Aluminum pill. Wired directly to the star and run with my DMM using it’s 6” long 12ga leads with gold plated banana plugs…
Lo to High with rested cells
Samsung 25R @ 4.13V 2500mAh
.02, .43, 2.37, 5.26A
Sony C4 @ 4.16V 2600mAh
.03, .46, 2.45, 5.44A
Efest 35A @ 4.20V 2600mAh?
.03, .46, 2.49, 5.60A
Samsung 20R @ 4.20V 2000mAh
.03, .48, 2.60, 5.70A
Sony C5 @ 4.15V 2600mAh
.03, .46, 2.50, 5.44A
Test cell @ 4.20V 1500mAh
.03, .48, 2.55, 5.69A
So it’s consistent pretty much across the board, with the top performing cells showing their customary margin of lead. I’m charging those cells that were not fully charged, but I expect they’ll be consistent with the others. I don’t know why this FET driver is showing lesser numbers than I’ve gotten previously unless it’s the T6 itself.
Previous tests were also with a single XML2 on copper?
