When I look at this thread in Chrome I see big white squares for all the pictures. I can view them by right-clicking and opening in a new tab.
When I look in Firefox there are no pictures and no squares to click on. This with No-Script checked to allow all scripts from the thread.
Nice flashlight mod. Seeing that MTG2 under that aspheric is kinda funny…. “Why is there a banana inside your flashlight?”
can not see the photos. i tried all three browsers. ( Firefox, Chrome, and IE.) every one elses photo posts & topics here on BLFwork fine, there must be somthing wrong with the photo site yor using or the hyperlinks in your OP.
Wow! That SK98 with the MT-G2 throws a wall of light doesn’t it! How does it look zoomed?
Very awesome build…how well does it handle the heat from that big ol’ emitter?
I really like how you make the copper slug to fill the hollow portion of the pill
If you haven’t done it yet, I recommend a tiny bit of NOALOX on the threads of the pill, will help it dump the heat to the body better than not having anything
Thanks everyone! I will take outdoor video tonight. After 70sec run on max body is too hot to hold and after 2 minutes too hold to touch. However, flashlight is very usable on other mods with loads of light. On low I’m reading 200mA and 1.9A on medium. Calculated runtime on max is more than 12 minutes so in short bursts it’s not too bad if you want massive wall of light right out of your pocket. Compared to my 100w halogen bulb rated at 1800 lumens without deffuser, to my eyes it is noticeable brighter. I would say it’s more than 2100 lumens and without lens over 2500. I’ve chosen zoomie over reflector based light because I wanted only flood in tiny package but still I have option of zooming for better throw, 120m easily. Heat managment in sk98 is very good since cooling fins are right under screwed pill and that’s the reason why I’ve chosen it over other zoomies.
Here is requested outdoor video . It’s captured with Sony Xperia U. Up-close objects are too bright and further objects are to dim. It doesn’t represent real experience, that’s why a had both lights just to get you an idea how it looks compared.
I had slightly problems with mode memory which I don’t like :Sp . You can see components in video description.
