Very impressive build and nice write up. You have a knack for this. 2 builds so far and both are impressive. Congratulations PH_Oton.
Good job fixing the pictures. Can see them with no problem in Firefox now.
Wow! That SK98 with the MT-G2 throws a wall of light doesn’t it! How does it look zoomed?
Very awesome build…how well does it handle the heat from that big ol’ emitter?
I really like how you make the copper slug to fill the hollow portion of the pill
If you haven’t done it yet, I recommend a tiny bit of NOALOX on the threads of the pill, will help it dump the heat to the body better than not having anything
Great job and awesome bling too!
Ok. Your teasing us. Now we all want to see outside shots, please.
i can see the photos now. Nice job on the mod !
makes a super-flooder palm-sized light with lots of wow-factor.
A work of art, truly excellent work!
thats wicked! whats the runtime on that thing…5 mins?
yes, outdoor shots would be awesome.
how many lumens is it about?
thanks for the re-upload -> works fin on every browser!
@ build:
excellent!
That is crazy - I really like it!
Thanks everyone! I will take outdoor video tonight. After 70sec run on max body is too hot to hold and after 2 minutes too hold to touch. However, flashlight is very usable on other mods with loads of light. On low I’m reading 200mA and 1.9A on medium. Calculated runtime on max is more than 12 minutes so in short bursts it’s not too bad if you want massive wall of light right out of your pocket. Compared to my 100w halogen bulb rated at 1800 lumens without deffuser, to my eyes it is noticeable brighter. I would say it’s more than 2100 lumens and without lens over 2500. I’ve chosen zoomie over reflector based light because I wanted only flood in tiny package but still I have option of zooming for better throw, 120m easily. Heat managment in sk98 is very good since cooling fins are right under screwed pill and that’s the reason why I’ve chosen it over other zoomies.
Here is requested outdoor video . It’s captured with Sony Xperia U. Up-close objects are too bright and further objects are to dim. It doesn’t represent real experience, that’s why a had both lights just to get you an idea how it looks compared.
I had slightly problems with mode memory which I don’t like :Sp . You can see components in video description.
VERY, very nice light and really good video demonstration. Thanks!
Beam looks great in flood and throw. Your video kind of swings around a lot. I imagine it's hard to work the light and record at the same time. Thank you for taking the time to provide the video. You got me wanting one of these now.
Man I really need an MT-G2 powerhouse! Hopefully, branded manufacturers can come with them or budget ones!
Great mod. Gorgeous finish.
Very good mod, thanks for putting up the pictures now. What is the small animal in the grass?
I’ve actually used four lights in video. First one is 10mm led photon clone from KD ( I am very satisfied with it) and second one is generic 5 led bike light. Four lights in four pockets :bigsmile: .
It’s my 4 months old dog. He follows me where ever I go
Oh, it's hard to tell in flood mode if you are just in low or medium mode. I probably should have looked for tint clues. At what times in the video are you using the light you built in the OP?
It would be good to know when the other 4 lights were used too.
Cool. I’m more impressed now having seen the video.
Last light is with MT-G2 as you can see from honeycomb beam patern. First one is keychain, second is generic 5 led and third is dedomed XP-G2.
Nice build mtg2 sk98 build!! I like the way you fabricated extra copper for the heatsinking, trust me, this light runs HOT when its zoomed out
For my build, I played cheat and used a bunch of singapore 1 cent coins (made mainly of copper) stacked against the back
Sadly though, it seems to lose a lot of light upon zooming out, probably need larger asperics as the sk98 is still too small, ive moved my mtg2 from the sk98 to a smiling shark sse7 (ultrafire z5 1x 28650 clone), aspheric is now 28mm instead of 20mm
Its a hollow pill, so I filled the entire length of with thermal paste and stacks of 1 cent coins
It seems to throw slightly better, have you ever considered shaving the mtg2?
