I guess it`s 9.99 ;)
Nice deal finds and great idea for a thread.
Thanks!
hopefully it will be useful for some people.
the p60 for $5 is pretty interesting
you want to punish someone?
$5.12 for shipping to the US. From the pics it looks well worth $15 though.
These are available from banggood for the same price. I have one inbound. Seems a little on the cheesy side but with built in charging port, audible alarm, attack head, side switch and side cutter there’s a lot there for $15.
Nice theme for a thread because of the obscureness of ebay. I suggest as a 'rule' in this thread that at least with every deal a picture is shown of what the deal is about.
very nice prices for budget conscious minded BLF flasholics
that double O rings light reminded me of Keenwin light :~
TrustFire F25
$8.09
I just bought one and there are 2 left.
http://www.ebay.com/itm/TrustFire-F25-XP-E-R5-14500-3-Mode-LED-Torch-Flashlight-/371255738312
Just saw this on eBay. Interesting concept. Anyone actually have it?
Want to know if the ‘lantern mode’ is actually usable, or not to bother with.
3-Mode Camping Lantern CREE Q5 LED Flashlight Torch Lamp 180 Lumens Waterproof
Features:
Super bright CREEQ5 LED flashlight.
Can be used as a flashlight torch and a camping lantern.
High tech bright LED with extremely long working life.
Made of high quality aluminium alloy.
Water resistant.
Three output modes: High, Low, Strobe.
ON/OFF switch on the torch’s end.
Ideal companion for camping, fishing, hiking, traveling, climbing, etc.
Specifications:
LED type: CREEQ5
Material: Aluminum alloy
Lumen: 180LM
Power: 100-240V
Battery: 1 * 14500 / 1 * AA battery
3 mode: high / low / strobe
Size: 10.5cm( length ) * 3.2cm( head diameter ) * 2.6cm( body diameter )
Weight: 88g
That’s the first single AA version i seen. Do you have a link?
I included the link in the original post.
Thanks for pointing that out.
found it. i don’t know how i missed that.
@pieman and DBSAR - aka Sipik SK51. some older links (Weird SIPIK SK51 1AA/14500 latern/zoom flashlight thingy and Cheap 'lantern zoomie' from dx)
http://slickdeals.net/f/7713635-supfire-f3-l2-cree-xm-l2-5-mode-led-flas…
https://www.myled.com/p9098-led-flashlight-cree-l2-1100lm-5-mode-white-l…
Use the code “15SD32” for discount.
Just tried thw code and it currently works.
I own two Supfire F3 L2s and thinking of ordering a few more.
not exactly ebay but still a good deal ;)
Thanks HBomb.
Didn’t realize this concept was already a few years old.
Wasn’t sure what to call this thing.
So far I’ve seen the following names similar to this design:
- Sipik SK51 (thanks HBomb)
- Zoomable Flashlight and Pop Up Lantern
- LED Dual Light
- LED Flashlight + Lantern 2 in 1
- Flashlight which extends to become a lantern
- Pop up LED lantern / flashlight combo
- Flashlight Lantern Combo
- Led Camping Lantern Flashlight Torch Lamp (
- Lantern Stretch Light
After some looking around, here are some I think fall into this particular combo catagory:
The Romisen RC-N3 is a versatile light that can use CR123A, 16340, and 2AA with the included extension tube. With a cool white Cree XR-E, it’s a thrower in a small form factor. Without the extension tube, it’s a compact stubby. With the extension tube it becomes a 2AA stick.
Tail current is 0.95A with a cheap 16340 and 1.9A with 2 AA alkaline cells.
Here are some features (plus and minus):
- OP aluminum screw-in reflector
- single mode
- forward clickie
- solid aluminum screw-in pill
- nice anodization
- anodized tail cap for lock-out or conversion to twisty
- thick walls
- thick glass lens
- o-rings
- nice wire belt clip
- does not tail stand
The main tube is sized for CR123A so there is some rattling when used with 2AA extension tube. I solved this by cutting 1/4” copper tubing to act as a sizing adapter.
I broke the tail switch after unscrewing it. Thanks to the anodized tailcap, I was able to convert the light to a twisty by adding a spring.
It’s a bargain for $6.83 shipped from the US. By 5 or more and get 5% off. I ordered two more before you take them all.
