Tom, this my first battery pack. My question is are the batteries connected together with welded tabs? If so, are they easily removed without damage. Do you dremel them off, or just leave them on cutting away as much as possible?
Just trim them if you want more height, a la mini-button, or grab the tab with needle-nose pliers and roll it off like opening a can of sardines with a key. (Do they still make those?) Then gently file down any sharp bits.
I usually just twist back and carefully with a pair of needle nose pliers. Then I clean up the leftover weld with my dremel very carefully. You can also use a file to smooth but takes longer
My pack came in today in nice ASUS retail box & padded envelope w/April 2011 sticker. All good.
I happen to be using the cells for a project that I’ll be making a 3S2P pack for & these will be perfect & are of course a great deal.
Quite the feeding frenzy & probably not limited to BLFers. I need the one pack I bought but maybe someone else here has a spare they could sell to you.
I just checked the tracking on my order and it shows “out for delivery”. Then the doorbell rings and I’m thinking, “It’s the mail man with my package!”
I run down the stairs to the front door, where I am greeted by a gentleman named Mr. Menard who would like me to join the Jehovah church. :~
Fedex just delivered a large box in perfect condition. The packs arrived neatly packaged in 10 OEM Asus boxes with their factory seals intact (Asus tape oval). Its to bad the laptops for these packs were from 2009 vintage or Id be looking for an old beater to use with all these packs… maybe (but probably not).
I get that a lot. The seller appears to have shipped using the most economical carrier to my address. Fedex is often the cheapest for me… not to mention that their level of service is usually far superior to their competition.
