I usually just twist back and carefully with a pair of needle nose pliers. Then I clean up the leftover weld with my dremel very carefully. You can also use a file to smooth but takes longer
Maybe he adds more.
My pack came in today in nice ASUS retail box & padded envelope w/April 2011 sticker. All good.
I happen to be using the cells for a project that I’ll be making a 3S2P pack for & these will be perfect & are of course a great deal.
darm. just sold out, the kicker is I have a asus UL50V that I pulled out of the trash because the battery pack wasn’t working right.
I hate the BLF kiss of death. harumph.
Finally sold out.
I successfully resisted! :party:
People have been wondering why I’ve been looking a little odd though. :Sp
whoa…. 163 sold! good thing I grabbed 7 of them J)
Quite the feeding frenzy & probably not limited to BLFers. I need the one pack I bought but maybe someone else here has a spare they could sell to you.
I just checked the tracking on my order and it shows “out for delivery”. Then the doorbell rings and I’m thinking, “It’s the mail man with my package!”
I run down the stairs to the front door, where I am greeted by a gentleman named Mr. Menard who would like me to join the Jehovah church. :~
And no, he did not have my batteries.
Fedex just delivered a large box in perfect condition. The packs arrived neatly packaged in 10 OEM Asus boxes with their factory seals intact (Asus tape oval). Its to bad the laptops for these packs were from 2009 vintage or Id be looking for an old beater to use with all these packs… maybe (but probably not).
so you get fedEx and the rest of us get USPS. I feel scroogled!
I get that a lot. The seller appears to have shipped using the most economical carrier to my address. Fedex is often the cheapest for me… not to mention that their level of service is usually far superior to their competition.
No idea how I managed to miss this thread…
I’m almost out of extra 18650 cells.
Thanks for this great deal.I just finished opening up the first of several packs and this is a very difficult pack to open.The most difficult one I have encountered so far.All 8 cells measured 3.6 volts.I will charge them up and check capacity in the next few days.
Got mine today! Ill crack em open tomorrow.
please make and show us some pictures…
Thanks again Siskiyou. Got mine today and successfully extracted the cells. My multimeter is at work, so I haven’t tested the cells yet.
This was my very first time doing something like this, so I don’t have anything else to compare it to, but I would say extraction wasn’t that difficult. I only used a flathead screwdriver and pliers. First, I stuck the scredriver right were the connector was, and twisted it. Then kept sliding it and twisting it, cracking open the pack along the way. I did this in both directions from the connector and had opened up half of the seam (quarter of the way from each edge). At this point I just took the pliers, and started pulling off the plastic. It was a bit harder towards the edges of the pack, but still doable.
One thing I can suggest, is to use pliers with thin tips. Mine had very thick tips, and at times it was hard to grab the plastic while avoiding pushing against the cells.
Before this pack I had 4 flashlights but only 2 cells (3400mah NCRB-s). Now I have 10 cells. Does this mean I need to get 6 more lights?
My Dad used to say that 9 out of 10 questions you can answer yourself. I think you already know the answer to that one. :bigsmile:
My first of 2 packs came today, and I must say this was the BEST deal yet! My pack was dated April 2011 and the box it came in looked retail fresh! It was also the hardest pack to open so far for me. All cells were exactly at 3.65V. All in all I don’t see how anything could be any better than this one. Thanks again to Siskiyou
Just finished cleaning up. Here are some pics
April 2011
If it is any consolation, this same seller has this ASUS 8 pack also for $9.99. Rated at 4400 mAh. So it probably only has 2200’s in it. Don’t know what brand, but probably also Samsung.
http://www.ebay.com/itm/Original-ASUS-Battery-90-NYX1B1000Y-A42-N82-K52-A31-B53-A31-K52-A32-K52-A32-N82-/111267236770?pt=Laptop_Batteries&hash=item19e80b4ba2
The battery looks so pristine, not a nick! Is that a solder blob on +?
What did you use to rid of the insulation gunk on battery?
Thanks Siskiyou, top notch find.
Don't leave us in suspense, did you join?
