True, the MM15 will be a ridiculous wall of light, like a SRK on steroids. I imagine the FFIV would be like a TK75 on steroids (alot of throw and spill)
On the early ones there were some focus issues, mine was around the 350 kcd mark after burn in. It is possible to adjust the focus but it is not a couple of minutes work. A friend worked with mine and got to over 460 kcd but we knocked it back to 400 kcd as I preferred the beam pattern.
Bulbs are readily available as are carriers, the last time I asked the ballasts as well, though whether if you lived in the States the lipslockin still applied I don’t know. AFAIK the only problems in the wild concerned a few carriers. There is a five year warranty on them anyway, applies with the lipslockin I presume?
Couple of things, Turbo is limited by a timer to 3 minutes not by a thermal switch.
If Turbo is not used, my standard FF4 has never thermally switched down to low from high, but then I live in the UK.
Concerning batteries, although the panny Bs & Gs work fine as do the Sanyo blue tops, the PD/PFs are better. I have used the 30a 2200 Sony and they also work very well the Sony 30a 2600s should also be fine and would have the runtime of the blue tops. The HD cells runs cooler and are better suited to the light and a necessity for a modded 4.
As for run-times I have never managed to get anywhere near an hour on high (standard FF4), in low yes. (on Bs) But now only use pd/pfs so obviously slightly less runtime.
Edit: Sorry should have said congrats chriszhou on getting the FF4 and the review!
It's amazing that LED flashlights are only just starting to catch up. Vinh's Supbeam X60 comes very close, but at nearly double the price and no longer for sale. There are a couple other lights that can match output, but I don't think any of those also have anywhere near the same throw. I'm eager to see what the BTU Shocker v2 is going to be like.
I think I had the giant ebay HID in mind when I typed that. The ebay hid handles the heat ridiculously well for the sheer amount of output. I can definitely see a lot more heat generated in the tiny (by comparison) FF4 package. I did happen to see a few of those burn videos with HID lights. Pretty entertaining watching someone scorch cardboard with a flashlight.
I wish. On turbo the FF4 generates an absurd amount of heat. Personally after I run it for a while, 10-20 minutes max, I take it apart, take batteries out, separate out the tube and head.
The head actually gets hotter, 2-3 minutes after the light is off. You could cook on it...
No need to imagine... http://laserpointerforums.com/f66/fire-foxes-4-vs-fenix-tk75-battle-big-lights-83918.html :D
Wonderful review, as far as i know, FF4 is the most powerful flashlight with long beam,except its “pocketable” design. I supposed that how long could FF4 run at Turbo mode. maybe 2-3 mins? it’s exactly suitable for flashight enthusias :bigsmile:
It brings the price down to $208 USD, at least it did when I used it…
Personally I chose Wallbuys because it was the cheapest option, although I’m not sure whether that is still the case.
Glad you liked it! Writing the occasional "review" like that gives me a huge amount of appreciation on how much work goes into a nice one, like the one posted. I especially love the mouse over shots.
Turbo is exactly 3 minutes, but the light will also step down if it gets too hot, or the batteries aren't keeping up.
I think HID will always blow away any single led light and many multiple led lights. I still prefer HID over any led, but the price for a good one is just to much.
That may still hold true for a while, but not for long. Already LED lights are beating HIDs in throw, and with multiple LEDs in overall output. The MTG2, a single LED is being pushed to over 3000 lumens all the time now.
It just seems that while there has been an immense move forward in LED technology (from ~2006-2007 when I started paying attention) the HIDs have not kept up.
Interesting views, I would like to beg to differ….
Just what stock LED light will beat this…… I would be interested in buying one 8)
I am also curious, what led lights are in the pipeline, again stock that would beat a FF4 for throw and output?
Multi MT-G2s have the potential output but the heat issues are great. I have tried unsuccessfully so far to tame the heat issues with a shocker and that is with active cooling. Not saying impossible obviously but difficult and costly.
Huge outputs will happen with conventional LEDs I agree but have the feeling that HIDs will always have an edge. Now laser phos lamps are a totally different ball game.
There are rumours of a FF4/5 size light with active cooling and 120w standard out next year along with the FF5, if shine wants to do another. I very much doubt any stock LED light that will be available, would live with them.
If you compare a very heavily modded LED light with a stock FF4 and say the LED throws further well ? Compare a modded FF4 with the modded LED for a fairer comparison.
There are some LED lights that are certainly compareable if you consider lumens and Lux. The main light that is a serious competitor is the Supbeam X60vn. And I am a previous owner of a FF4 and did full testing on both lights. I did sell the FF4 actually to help pay for the X60vn.
The numbers on my FF4 - 7010 lumens & 430kcd (on PD’s)
The numbers on my X60vn - 6865 lumens & 460kcd (on 20R’s)
So very compareable. And the FF4 had one of the better combos of throw and lux among normal handheld HID’s. It is an awesome light. I just love the LED practicallity of the X60vn so much better.
And - GREAT REVIEW ON THE FF4 OP!
